2G CV boot replacement
Just make sure you get the right ones there is a inner and outer boot oem are the best the universal boots dont fit good on our cars and dont tend to last as long.
Also, make sure that area on the axle cup where the boot goes on to it is absolutely....positively clean! as in no grease on it and the same goes for the inside of the boot too. If not, there is more of a chance that the boot end will work itself off from the axle cup, no matter how tight you make the clamp. I've had that happen and a couple of times, so I called Drive Shaft Shop and they explained that was the why it was happening.
Just my .02...hope it's useful.
