cuts out on turn
92awdbird
62
Jan 8, 2010
kula, Hawaii
i got a 1gb and i have installed a 190 pump. i have a issue with left turns. car cuts out when in a high g left. any ideas?i need to logg this but i cant get the logs on the comp. any one know how? is there a thread for this? Thanks!!!!
i got a awd 1gb but it will do it on half tank. ill need to fill her up and hit the curves while logging i guess. but i know that it is bogging out. i got a lc-1 with a maft gen 2 useing the wb tracking at 11.6 afr. i know i need to change the fuel filter"im at 46000 miles" but have had trouble at getting the lower flare nut off. i caped the vent line. not sure that was good.....it will hold tank press and wont let me start the car....loss of fuel press i guess. any ideas?
Gas tank pickup tube may be partially broken (common) and moving around.
Other than the sock on the end of the pump what pickup tube are you thinking of.
I don't have the problem unless the tank is less than 1/4 full. Unless you sump the tank or build a surge pot/tank I'm not sure there much you can do about it but keep your tank filled up.
I have a 1g AWD tank in my Colt, and it does the same thing when I start getting down to 1/4 tank or less. The pump is on the driver side, so that's just how it is. I have a fuel pressure gauge on the dash, and know what's happening, so I just don't floor it around hard lefts when the gas is low.
If I have 1/8th tank or less it can take several minutes to prime the pump again.
I make sure I have at least a half tank or more when I arrive at the track.
