omegis13
- 96
- 1
- Sep 14, 2004
Altus,
Oklahoma
Before I even begin; please, no flaming or comments that lack any sort of engineering/experience-based support
Here in Oklahoma, Abel Racing out of Midwest City successfully bolted an Evo 8 exhaust manifold, turbo, and o2 housing to a dsm 4g63 for their shop drag car. The car ran low twelves with this setup. This required ALOT of modification to the accessories on the block, including relocating the alternator and modifying the neck on the water pump. This doesn't even include the fact that the setup required a custom intake (compressor on the driver's side = ###) and intercooler piping. Despite all this, it was one of the most kick ass thing's I've ever seen done to a DSM.
As for most dsm performance enthusiasts, what they did is not a realistic option, especially for a street car. And for running a stock evo turbo, it wouldn't even be worth it. HOWEVER, to run an upgraded evo turbo, such as maybe twin scroll 20g or better yet; a twin scoll Garrett hybrid; could the benefits of twin scroll over the stock style td05h turbine setup be worth it? Could it be worth a person's time to build a custom tubular manifold that allowed a evo style turbo and o2 housing to bolt up to a dsm?
I figure such a manifold would be designed as such:
Turbo flange would the same left/right positioning as the dsm turbo flange
Evo turbo flange would need to be turned 180* to put the compressor on the passenger side of the car.
The runners would need to be shortened as the inlet to the turbine housing is sitting closer to the block. Anything near stock would put the turbo into the radiator/fans.
So in short, with a direct comparison of ONLY the stock turbine setup and evo turbine setup (not compared to Garrett setups), would the performance benefits be worth it? As I understand, the twin scroll setup on the evo allows it to similarly sized turbos faster and still have better top end power. Cost is not a factor in this discussion; I only wish to discuss the performance aspects of the setups (I do realize how expensive this custom this custom manifold would be and how much labor and RnD would go into its development). If you MUST make a Garrett-based comparison, make it only on the basis of performance between the Garrett setup and evo setup, and keep these comparisons serious and comparison. Also, in making any comparison, keep in mind the goal I have in mind for such a setup is to build a VERY streetable car that would have good spool times for auto x, as well as good top end power for drag racing. Also, if it helps anyone here, when Abel Racing bolted the evo turbo setup to a dsm motor, the stock o2 housing lined up PERFECTLY with their bolt on-style down pipe; positioning suggests that the evo manifold is a mirror image of our stock manifold design where left/right positioning of the turbo flange is considered.
YES, I know I am insane, cannot afford this pipe dream, and everything other reason to back the question "why would you want to put an evo turbo on a dsm when you could just do a bolt on Garrett or full Garrett setup?"; so don't ask this question. This is merely an investigation into the possible benefits of the evo's twin scroll setup to our cars over more "traditional" setups. As for more exotic setups, like a direct bolton for a stock Holset turbo, you're once again looking outside the bounds of my question. I think I've given the parameters from which I want to operate within, please stay within them on this thread (if you need it in black and white; compare the twin scroll setup to our stock setup, do not factor in money/time/pain in the ass factors, or other alternative to the two setups being comared.).
Thanks,
Greg Heineken
Thanks,
Greg Heineken
. I'll definitely get in contact with them in the next couple of weeks. I'll send them pics of DN peformance's evo manifold for reference, although a twin scoll t3 sounds much more appealing
) However;
