cruise log please advise
dynedta
33
May 10, 2010
Massillon, Ohio
ok here is my cruise log and from what I gather via "basic tuning" outline im ok to continue with WOT tuning. please advise!!
To answer your question about being ready to go WOT, the answer is most definitely no. You have no way of monitoring the engines AFR until you get a wideband gauge.
First download the most recent stable version v3.21.40 and then download early access v3.21.109 from the ECMLink Downloads page. After doing this you'll want to update your firmware as well but to do so its a bit trickier than just clicking a link.
  1. You'll want to submit a firmware request and to do it requires you to connect to your cars ECU. Click ECU from the drop down and click Create Firmware Request... paying close attention to where its saved on your computer.
  2. Request Firmware Upgrade... and select Choose File and find your firmware file you just saved.
  3. Download the new firmware to your desktop or somewhere you can easily access it and then open up ECMLink.
  4. Click the ECU drop down menu and select Upgrade Firmware and then pick the file you just downloaded while your connected to the ECU in the car.
Then get a WB gauge and start logging it, after you do this we can talk about doing WOT pulls. Rather than doing a drive log just post a log of the car idling once its warmed up to 180*. Are your profile mods updated? I don't see aftermarket injectors listed but you're running a -18% global for 550's.
I also suggest dropping the Knock CEL to 2*, currently its a 4* and once you hit that much bad things could've already happened.
:dsm:
profile updated (im using evo injectors), downloaded updates, will update firmware tomorrow. I'll also be ordering my wideband tomorrow aswell. What kind of log should I do from this point? idle w/ wideband? cruise? also note taken on changing the knock CEL count. thanks alot for the direction!!!
