ECMlink Cruise log. Going way lean under any boost.
Rideit636
82
Nov 9, 2010
Provincetown, Massachusetts
Here is a log cruising to work this morning. I pulled a degree of timing across the board just for safety until I figure this out. I added 20% fuel across to try and get it down to 11ish. Should I add more fuel, or compensate with MAF adjustments? What am I missing? As you can tell I am very new to Link.
You got 6 degrees of knock at 86 seconds, your throttle position was only 38 percent and with just cruising. I would adjust your knock sensor to only read if your at 45 percent throttle or more. anything Below that you are probably just getting engine noise. also under dash I would change your coolant temp to 220 instead of 230 you will want to be warned there getting high before they reach that high.
here is a great thread for tuning even if your not running speed density its a great break down and over view step by step.
http://www.dsmtuners.com/forums/articles-tuning-ecu/395564-how-tune-1g-v3-sd-ecmlink-no-maf.html
If you have added that much fuel and your still running lean id check your actual fuel pressure. from what the log shows it looks to lean for that much fuel. so i'd suspect you have a misadjusted regulator or maybe a failing fuel pump or a leak in the tank at the pump. just a thought
