Crazy Idle
white95gst
Apr 10, 2007
NY, New York
I have a 95 automatic GST. When I start the car the idle jumps right up to 2000 and goes down slowly and the car just dies. To keep the car running I must keep pumping the gas, however when I do this I hear alot of popping noise(backfire). Also the cars turbo is removed could that be the cause of the problem? The battery light comes on when the car is started but both the battery and altenator is new. Also the under hood fuse box the last two realays on the passanger side is missing, but I dont believe that is the problem because the car was running with out them for a while. So for writing so much but i wanted to describe everything!
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
