Crazy Idle
megadeth0
247
4
May 13, 2004
Spanish Fork, Utah
:dsm: I can't seem to figure out this idle. My timing marks at 1K move from 1 to 5*, I ground the terminal and adjust the BISS to 1100 RPM and the next time I start the car up, it idles at 2K. If I adjust it down to 1100 again, the idle drops to 550 on the next start up. I highly doubt that it is the Idle Speed Control because the idle is consistant while it is running. Any ideas???
Well if you have done a boost look test, have no CEL's/know all your sensors are good, and are setting the BISS according the VFAQ then it's probably an ISC problem.
I just installed DSMLink and the idle is a ton better. It still bobbles a little bit but I may be able to tune it out with the Link. I checked the ISC and got 38 Ohms on all 4 coils. Is this sensor bad? Book sais 28-33 I believe.
megadeth0 said:
II checked the ISC and got 38 Ohms on all 4 coils. Is this sensor bad? Book sais 28-33 I believe.
I checked my new ISC and I had 40 on all 4, and it has been working fine so far. So 38 should probably be fine.
Are you sure that you do not have a boost leak? Your ISC sounds fine, but I suspect that you either have a boost leak, or that one of your sensors is unplugged. You should also set your base timing too!
Base timing has been set already. I will check for boost leaks this week. Maybe it'll be the damn throttle body shaft seal(damn).:rocks:
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
