kutta
- 30
- 0
- Mar 11, 2009
Manchester,
Connecticut
So Here is my Situation. I received a 6 bolt engine that was running fine and decided to pull it apart before installing. Noticed that their were some scratches on the crank so I had it polished. By the time I got it back I noticed that the main bearings were .01 inches (.25mm) , (undersized or over sized) and the rod bearings are .02 inches (.5mm) as well. So My question is in regarded to weither or not I'm going to be ok with my specs.
So Standard specs are for main 2.2433- 2.2439 inches. And for rod bearings it is 1.7709-1.7715. So Since the crank is using oversized bearings I just subtracted .01 from the main tolerances and .02 from the rod tolerances to get this....
Main tolerances for .01 (.25mm) bearings = 2.2333-2.2339
Rod bearing tolerances for .02(.5mm) bearings= 1.7509-1.7515
So out of round slack is 6/tenths (.0006)
So After the crank was polished heard are my measurements stated below
I took two measurements for each
Main
m1 2.2333/ 2.2330
m2 2.2333/ 2.2335
m3 2.2333
m4 2.2335
m5 2.2335
So the lower tolerances for the oversized bearings was 2.2333 and on one of them I'm .0003 off.
Then for the rods I have
r1 1.7505/ 1.7502
r2 1.7505/1.7505
r3 1.7505/ 1.7505
r4 1.7504/ 1.7510
and the Tolerances for the crank for the rods for .02(.5mm) oversized was
1.7509-1.7515 inches.
So as you can see for the rods I'm .0004 -.0007 on one and .0004 on the other. and .0005 on one... Is this going to be ok????
So This sucks because for the ACL tri metal bearings they dont make a .5mm for the rods that I'm aware of. So I have to go with the aluminum ones.. If these tolerances are going to be ok should I run all aluminum or do trimetal ACL for the main and the aluminums for the rods. My goals for this car are going to be a solid daily driver with 350 to 425 HP max as I have a Forced performance 68hta Sitting in My house waiting to be used and some 272/272 cams and other fun stuff. Thanks for the help guys. I know Some people are not as picky about this stuff but I dont care for fast cars that run for only a season. Thanks for the Help
Main
m1 2.2333/ 2.2330
m2 2.2333/ 2.2335
m3 2.2333
m4 2.2335
m5 2.2335
r1 1.7505/ 1.7502
r2 1.7505/1.7505
r3 1.7505/ 1.7505
r4 1.7504/ 1.7510
