crank seal still usable?
sliver
92
Aug 25, 2008
me, Texas
I had a hard time getting this seal in. While doing it I had managed to make some little knicks. I'm wondering if this will affect anything..I don't want a oil leakage. No biggie I just rather use the $14 on oil or something besides ANOTHER seal.
I can't even tell from this pic you need to get a better one up.
But just to be on the safe side i would just spend the $14 dollars on a new one.
Are you blind? Look at the lip.
I already ordered another one, just need a few opinions. BTW, what's a good technique to get these things in without messing it up? I don't think I have a socket big enough for it. This thing was a bi*** to get in.
since you want to be so ignorant here is the bottom line.... if you already ordered a new one , why did you ask????????????? and if you messed it up some, why take the chance.you anw=swered your own question.
No i'm not blind..you asked for imput and that's what i gave you next time don't ask if you are gona act like a little kid.try to invest in a better camera.
Also the pic you posted up has a 2007 date..wtf?
I did my seal about two months ago and all I did was pop it into place, put a flat peice of board on it and tapped it in with a rubber hammer. I have not had any leaks so far. :talon:
It looks like those nicks are on the exposed part of the steel ring, the part of the seal that does no sealing. There are three places where a nick could cause a leak; the crank itself, the block where the seal sits, or the outside portion of the seal that mates to the block. As long as none of those were messed up, and the seal is in straight you are fine.
If you don't have a large enough socket, use a piece of 2x4.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
