Crank Position Sensor in 1G Swap
lccynmbr13
232
Sep 10, 2006
Renton, Washington
I'm putting my new 6bolt in my 2g tonight. I had the motor built by a performance shop and everything was supposed to be in/attached to the motor that need be minus bolt-ons. I'm looking in my Chiltons and it has a section on CPS but it is not year specific for some reason. I was looking at my old 7bolt block and theres a clear place for the sensor to bolt up to but on 6bolt I can't find the place for it to bolt to. I'm starting to think that maybe the 6bolt doesn't even use a CPS? I'm trying to use my 7bolt CPS so maybe the 6bolt is different if there even is one for it? Thanks for your help I really need to get this in tonight.
If you are asking that question, someone didnt do their research.
http://www.roadraceengineering.com/1gcasin2g.htm
Im not going to rain on your parade.....
Are you sure you have everything else ready to go to drop it in?
Actually I did do my research... Your link is for the Cam Angle Sensor (CAS) my question is about the Crank Position Sensor (CPS) and yes I do have everything else ready to go.
What Absolute is refering to is that 1g's don't have a CPS but have a 4 pulse CAS whereas 2g's have a 2 pulse CPS and a 2 pulse CAS. So his link explains how to handle this for the 2g wire harness.
Sounds to me that he's right - someone didn't do their research and maybe you owe him an apology for linking you to a common solution.
Sorry I should have elaborated, but what luv2 says is exactly what I was refering too. And that is why I asked if you have everything else ready to go.
Heres a tech article, Im not tryin to be a dick (all the time) but I would hate to see posts like "why wont the 6 bolt go in?" or "the fresh 6 bolt wont run?"
http://www.dsmtuners.com/forums/showthread.php?t=152329
Im kinda jealous, my 6 bolt for my 97 is still on the stand.
