Crank issues/HB
bs4life
Jul 12, 2005
Orlando, Florida
So I have replaced my HB as well as all the belts on my 95 GST and my HB is still rubbing against the timing belt cover making a horrible noise. What else could be the cause of crank movement? I know the HB hasnt seperated and the car runs fine but just sounds like shit. None of the signs of crank walk are there either so I have no clue. Anyone else had this problem or have any ideas? :confused:
Just got back from Mitsubishi, the damage is a missing keyway so my crank sprocket has play in it as well as a balance shaft going bad? So basically it came down to labor being more expensive than just replacing the engine. So now I have the job of picking out a new motor to drop in it. Anyone have any suggestions on that?
