Couple Issues I am trying to resolve...
90gen1tsi
82
Jan 4, 2011
Olympia, Washington
Ok First I have a CEL coming on, It is a bad injector code, I checked all injectors and they are all within spec being between 2.8 and 3 ohms.
This CEL goes away with the slightest tap of the throttle and returns at idle.
Also sometimes when I have driven the car then shut it off and come back later after going to the store or whatever, it will start then die. It will run and idle fine after I give it some gas and drive it for just a min.
I am wondering if it could be a leaking injector or maybe the TPS?
Next I did a vacuum canister removal and EGR blockoff plate, before this I was hitting 14 lbs boost no problem. Now I am hitting 10 and creeping to 15, not sure why it would change? Yes I did cap all open vacuum ports.
Thanks for any help!
Checked the alternator today, charging at 14 volts at an idle... That should be fine right?
How did you check the code? Injector code is 41... but the tps code is 14 :hmm:
14 read likes this LONG.....short..short..short..short....LONG...short..short..short..short
41 reads like this LONG..LONG..LONG..LONG.....short..... LONG..LONG..LONG..LONG
I see a probability here that there may have been some confusion perhaps, especially is you caught the thing mid cycle. All you see is 1..4..1..4..1..4..1.
Unless this was pulled from a logger, i bet your code is 14 for the tps :thumb:
Well First thing I will do Saturday is check the code again! Thank you so much for the help and for the diagram! I do well with mechanical stuff but the electrical problems leave me scratchin my head!!!
