cooling your turbo
2bar4g63t
156
Oct 29, 2002
just got another 2g turbo, but this ones awd and stock. my other car is running a garret 60-1, but this one I was thinking of using a 20g, because it seems to me since our cars have the oil and water cooling for the stock t-25s, the 20g which utilizes both would be more effeicient and have more longgevity than a comparable sized garret which is only oil cooled, am i correct in assuming this? if we have two ways of cooling it down why block one off, seems like the garretwould get half-ass cooled, right?
you can have both 360 deg bearing and water/oil cool center section though.
the ONLY ones that have water cooled still use a 7cm2 housing like the one SBR and FP uses. AGP and PTE use custom housing that were meant to bolt up to Mitsu mani & o2 housing BUT at heart still are oil cooled like all Garrett Turbos
But Garrett center section can be swapped with oil cooled or oil/water. As much as I know both garrett center sections are same design and mounts the turbine and compressor the same.
pinknuggit said:
hopefully this one won't blow up like your last one! :D
what are you talking about, of course it will, LOL, but 4g63's are cheap so it'll be. okay anyway, so the bearings in a garrett turbo are better/more durable than a mitsu, and the additional watercooling has no benifit? than why would anyone ever but a mitsu turbo, other than not wanting to buy a compatible manifold?
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
