Cooling help?
matt98eclipse
1,078
Aug 15, 2006
mesa, Arizona
Hey guys im almost finished with my new setup but i need some help with my cooling system. My new turbo setup with the holset H1C wont allow me to run the stock radiator fan. So i think im gonna have to go with some sort of slim fan. I am on a really tight money budget. Are some ebay slim fans Decent?? Also should i do i push or pull type?
This cars not gonna be a daily driver and ALL my ac, heater core and power steering stuff is all removed.
Any help would be great. I have never used or installed a slim fan so ill probly just use a toggle switch with it.
a fan is a fan im pretty sure the ebay ones work just fine just make sure they bolt on right to your raidiator and connect it to your switch.. and pull i think would be best .. its pulling cooler air from the outside...
I just installed an ebay slimline fan, works fine.
Get the biggest fan you have room for with the most CFM, and get the pull type, most of them are reversible.
Cut the plug off your old fan, splice it on your new fan, and its plug and play.
Make sure your fan comes with an install kit or buy one separate. The install kit is just 4 zip tie like things, that you push thru the radiator fins from the opposite side.
I have the Procomp one's on my car and they work great down here. 2 12" fans.
the pusher fans are great my friend installed them in front of the raidiator and it makes the engine bay look way better... next time i take my radiator out im gonna switch them.
