Cooling problem
microgalant
111
Aug 27, 2006
Aruba, South America
My car begin to overheat, but i don't know where to start,i've bought new radiator cap, flush the system , but it still overheat.
I don't know if the waterpump is bad, or the car has a leak.
I've put a vid so you guys can see, it seems that the waterpump is bad.
So what do you guys think
First things to check in this order:
Thermostat
Water pump
Coolant Temp sensor
Radiator fans
A leak you would see; if your head gasket is leaking your exhaust will smell sweet and possibly have coolant in your oil.
If the thermostat is stuck in the closed position you can overheat your car, stuck in the open and it will take forever to warm up.
Thermostat
Water pump
Coolant Temp sensor
Radiator fans
Don't have termostat, temp is ok, fans works, no oil in my coolant...
When I start the car, and leave it idle, it works fine, fans start and stops, open the radiator cap, you see the water flow, but when i ride the car, all the coolant goes into the reservior tank...btw I have new radiator cap....
doesnt every car have a thermostat?? im sure they do maybe thats your problem then LOL:sneaky: have you change your timing belt recently! i remember when my friend first did he never changed the pump at the same time and went bad 5 months after! thats all i can think off check that your rad isnt rusted as they can get that way.
also watching that video makes me think if its going in the over flow pipe then its not going in the coolant pipe (guess) so maybe there is something blocking it in the pipe in the exit/entrance of the rad? i know you said you flushed it but worth a shot just incase its something small (dont know how it would of got there though)
when the car idle it works fine, no problem, it happen when i ride the car, and boost it, all the water goes in the reservior tank.
I took the termostaat out my car, about 4 years ago
If you are pushing coolant under boost, it means you have a head gasket issue.
Seems to bubble a lot in the water.... looks like the time to check for the headgasket:cry:
Hmmm I have a new cometic headgasket on it, I did just dyno the car last week....or maybe I need to retorque the head?
I'll do a compression test
+1 on the thermostat. I was going to suggest testing yours in boiling water to see if it opens up correctly. You could always opt for a lower temp. one. Have you considered using an additive, such as Redline Water Wetter?
Ok took the head off today..
HEADGASKET GONE?????
Replace the head gasket.
Also, factory head bolts need to be replaced every time you remove the head; they're torque yield. Since the head is off you should replace the pos head bolts with some ARP's.
Is that an OEM head gasket or aftermarket?
Was the head torqued to spec in the correct order when it was last replaced?
If you've been overheating there's always the possibility that you warped the head & the head gasket was just the result of the head being warped. I've seen this happen in the past.
