Cooling System Upgrades
^Is that Celsius or Fahrenheit?
HAhahahahahahahahahahahah....ROFLROFL
That was HILARIOUS.
Thats crazy your temps stay that low..It makes absolutly no sense that you can restrict 90% of your airflow to the radiator with the fmic, but still keep temps like that.Good for you I guess...:rocks:
With that said, I would hardly call that a 3rd gear pull.You stopped at 5700...whats up with that? :D Lets see those temps at like 7k...Not that Im arguing that its not maintaining low temps, Im just curious to see if they move at all.
The intercooler still flows air through it. It slows the air down but if it cools then it has air coming out of it. And that air (warmer only in boost) gets to the radiator. Good ducting to the IC heps the IC work better and helps the radiator cool better.
I understand it goes through it but its still not as efficiant as it should be.But it really doesnt matter either way.:boring:
That was HILARIOUS.
LOL... Well I was coming up hardcore style on some traffic. So, I had to let off. I can see if I have an older 3rd gear pull on here. But, I think it'll yield the same results. :D
I'll bring my laptop with me to work today and search through some logs for you... Or I might just pull a brand new one on the way in.
Heat-wrapped manifold, turbo, o2 housing. A/C fan in, aluminum radiator, oil cooler setup, no a/c, SSAC FMIC Kit with just some rubber to seal up the aluminum radiator. I actually need to switch to a higher temp thermostat, as soon as mine hits the thermostat at 180 it drops back down to 172, which is a bit cold. Located in Virginia/DC area, trust me, tons of traffic. Make sure you guys are running heatshields/heatwrap
Here's another 3rd gear pull. This time from 2500rpm to 7200rpm as empie requested. I did this against my better judgement as 7200 rpm in 3rd gear is well above any speed limit here in KC.
I am limited on how long I can make the log here but as you can see the temperature starts out at 195* and stays there throughout the pull. After the pull it raises 3* to 198* then what I couldn't show due to space limitations is that it returns to 195* after some normal driving and then drops down to 189* while sitting in the Wendy's drive thru.
As you can see I need to do something about my intake temperatures! Holy Cow!!
Enjoy!
Code:
<html xmlns:o="urn:schemas-microsoft-com:office:office"
xmlns:x="urn:schemas-microsoft-com:office:excel"
xmlns="http://www.w3.org/TR/REC-html40">
<head>
<meta http-equiv=Content-Type content="text/html; charset=windows-1252">
<meta name=ProgId content=Excel.Sheet>
<meta name=Generator content="Microsoft Excel 12">
<link rel=File-List href="062809%20to%20OPCC_files/filelist.xml">
<style id="062809 to OPCC_13801_Styles">
<!--table
	{mso-displayed-decimal-separator:"\.";
	mso-displayed-thousand-separator:"\,";}
.xl1513801
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:black;
	font-size:11.0pt;
	font-weight:400;
	font-style:normal;
	text-decoration:none;
	font-family:Calibri, sans-serif;
	mso-font-charset:0;
	mso-number-format:General;
	text-align:general;
	vertical-align:bottom;
	mso-background-source:auto;
	mso-pattern:auto;
	white-space:nowrap;}
.xl6313801
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:black;
	font-size:11.0pt;
	font-weight:400;
	font-style:normal;
	mso-font-charset:0;
	text-align:center;
	mso-pattern:auto;
.xl6413801
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:black;
	font-size:11.0pt;
	font-weight:400;
	font-style:normal;
	mso-font-charset:0;
	mso-number-format:Fixed;
	text-align:center;
	mso-pattern:auto;
.xl6513801
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:black;
	font-size:11.0pt;
	font-weight:400;
	font-style:normal;
	mso-font-charset:0;
	text-align:center;
	border:.5pt solid windowtext;
	mso-pattern:auto;
.xl6613801
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:black;
	font-size:11.0pt;
	font-weight:400;
	font-style:normal;
	mso-font-charset:0;
	text-align:center;
	mso-pattern:auto;
.xl6713801
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:black;
	font-size:11.0pt;
	font-weight:400;
	font-style:normal;
	mso-font-charset:0;
	text-align:general;
	mso-pattern:auto;
.xl6813801
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:black;
	font-size:11.0pt;
	font-weight:400;
	font-style:normal;
	mso-font-charset:0;
	text-align:center;
	background:yellow;
	mso-pattern:black none;
.xl6913801
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:black;
	font-size:11.0pt;
	font-weight:400;
	font-style:normal;
	mso-font-charset:0;
	text-align:center;
	background:yellow;
.xl7013801
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:black;
	font-size:11.0pt;
	font-weight:400;
	font-style:normal;
	mso-font-charset:0;
	text-align:general;
	background:yellow;
.xl7113801
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:black;
	font-size:11.0pt;
	font-weight:400;
	font-style:normal;
	mso-font-charset:0;
	text-align:general;
	border-top:.5pt solid windowtext;
	border-right:none;
	border-bottom:none;
	border-left:.5pt solid windowtext;
	mso-pattern:auto;
.xl7213801
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:black;
	font-size:11.0pt;
	font-weight:400;
	font-style:normal;
	mso-font-charset:0;
	text-align:general;
	border-right:none;
	border-bottom:none;
	border-left:none;
	mso-pattern:auto;
.xl7313801
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:black;
	font-size:11.0pt;
	font-weight:400;
	font-style:normal;
	mso-font-charset:0;
	text-align:general;
	border-right:.5pt solid windowtext;
	border-bottom:none;
	border-left:none;
	mso-pattern:auto;
.xl7413801
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:black;
	font-size:11.0pt;
	font-weight:400;
	font-style:normal;
	mso-font-charset:0;
	text-align:general;
	border-top:none;
	border-right:none;
	border-bottom:.5pt solid windowtext;
	mso-pattern:auto;
.xl7513801
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:black;
	font-size:11.0pt;
	font-weight:400;
	font-style:normal;
	mso-font-charset:0;
	text-align:general;
	border-top:none;
	border-right:none;
	border-left:none;
	mso-pattern:auto;
.xl7613801
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:black;
	font-size:11.0pt;
	font-weight:400;
	font-style:normal;
	mso-font-charset:0;
	text-align:general;
	border-top:none;
	border-left:none;
	mso-pattern:auto;
</style>
</head>
<body>
<!--[if !excel]>&nbsp;&nbsp;<![endif]-->
<!--The following information was generated by Microsoft Office Excel's Publish
as Web Page wizard.-->
<!--If the same item is republished from Excel, all information between the DIV
tags will be replaced.-->
<!--START OF OUTPUT FROM EXCEL PUBLISH AS WEB PAGE WIZARD -->
<div id="062809 to OPCC_13801" align=center x:publishsource="Excel">
<table border=0 cellpadding=0 cellspacing=0 width=730 style='border-collapse:
 collapse;table-layout:fixed;width:548pt'>
 <col class=xl6413801 width=64 span=2 style='width:48pt'>
 <col class=xl6313801 width=64 style='width:48pt'>
 <col class=xl6313801 width=90 style='mso-width-source:userset;mso-width-alt:
 3291;width:68pt'>
 <col class=xl6413801 width=64 style='width:48pt'>
 <col width=64 style='width:48pt'>
 <col class=xl6313801 width=64 span=2 style='width:48pt'>
 <tr height=20 style='height:15.0pt'>
  <td height=20 class=xl7113801 colspan=3 width=192 style='height:15.0pt;
  width:144pt'>TechnoMotive Datalogger</td>
  <td class=xl7213801 width=90 style='width:68pt'>&nbsp;</td>
  <td class=xl7213801 width=64 style='width:48pt'>&nbsp;</td>
  <td class=xl7313801 width=64 style='width:48pt'>&nbsp;</td>
 </tr>
  <td height=20 class=xl7413801 style='height:15.0pt'>&nbsp;</td>
  <td class=xl7513801>&nbsp;</td>
  <td class=xl7613801>&nbsp;</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>Time</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>Air Flow</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>Air Temp</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>Coolant Temp</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>RPM</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>IPW</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>Knock</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>O2v</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>AFR</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>TPS</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>Timing</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>203.69</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>81.87</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>126</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>195</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>3156.25</td>
  <td class=xl6713801 align=right style='border-top:none;border-left:none'>2.3</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>0</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.27</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>14.18</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>21.18</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>39</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>204.06</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>3125.00</td>
  <td class=xl6713801 align=right style='border-top:none;border-left:none'>2.05</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.29</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>14.24</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>20.39</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>204.44</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>75.58</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.19</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>13.94</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>18.82</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>204.81</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>62.98</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>3093.75</td>
  <td class=xl6713801 align=right style='border-top:none;border-left:none'>1.79</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.07</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>13.58</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>17.25</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>38</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>205.19</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>56.68</td>
  <td class=xl6713801 align=right style='border-top:none;border-left:none'>1.54</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.01</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>13.40</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>15.29</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>205.56</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>44.09</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>3062.50</td>
  <td class=xl6713801 align=right style='border-top:none;border-left:none'>1.28</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>1.74</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>12.58</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>10.59</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>205.94</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>37.79</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>124</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>3031.25</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>1.5</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>11.86</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>206.31</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>31.49</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2968.75</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>1.78</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>12.70</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>25</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>206.66</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>123</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2937.50</td>
  <td class=xl6713801 align=right style='border-top:none;border-left:none'>0</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>207.00</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2875.00</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>3.3</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>17.28</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>24</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>207.38</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2843.75</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>4.8</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>21.79</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>13.73</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>37</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>207.75</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>122</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2812.50</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>4.63</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>21.28</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>14.51</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>208.13</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2781.25</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.95</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>16.22</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>14.90</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>208.50</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2750.00</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>208.88</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2718.75</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>209.25</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>209.59</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>121</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2687.50</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>1.99</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>13.34</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>209.97</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>210.34</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2656.25</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.03</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>13.46</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>12.16</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>210.72</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2625.00</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>1.97</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>13.28</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>211.06</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>25.19</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.13</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>13.76</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>211.41</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2593.75</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.68</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>15.41</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>23</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>211.75</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2562.50</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>3.63</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>18.27</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>212.09</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>120</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2531.25</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>212.44</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2500.00</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>212.78</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2468.75</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>213.13</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>4.82</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>21.85</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>213.47</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2437.50</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>27</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>213.81</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2406.25</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>12.94</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>35</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>214.19</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>4.22</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>20.04</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>214.53</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2375.00</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.48</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>14.81</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>214.91</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.17</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>13.88</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>14.12</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>215.28</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>2343.75</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.09</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>13.64</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>215.63</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>216.00</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.05</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>13.52</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>27.84</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>31</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>216.34</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>113.36</td>
  <td class=xl6713801 align=right style='border-top:none;border-left:none'>4.1</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.85</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>15.92</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>38.04</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>216.72</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>151.15</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>121</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>195</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>2468.75</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>4.86</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>0</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>2.34</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>14.39</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>52.94</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>23</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>217.09</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>176.35</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>122</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>2562.50</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>5.63</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>2.05</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>13.52</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>65.88</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>21</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>217.44</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>201.54</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>123</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>2625.00</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>6.4</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>1.86</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>12.94</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>83.92</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>19</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>217.78</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>233.03</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>124</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>2718.75</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>7.17</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>1.68</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>12.40</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>97.65</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>18</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>218.13</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>258.22</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>126</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>2843.75</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>8.19</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>1.52</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>11.92</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>100.00</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>17</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>218.44</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>302.31</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>127</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>2937.50</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>9.47</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>1.39</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>11.53</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>15</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>218.72</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>352.69</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>3062.50</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>11.01</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>14</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>219.03</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>421.97</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>128</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>3187.50</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>12.8</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>13</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>219.34</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>516.44</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>3343.75</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>14.85</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>1.21</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>10.99</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>219.66</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>629.80</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>3500.00</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>15.62</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>1.25</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>11.11</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>12</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>219.97</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>648.70</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>129</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>3718.75</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>15.36</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>1</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>1.27</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>11.17</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>220.31</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>667.59</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>3875.00</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>15.1</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>1.37</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>11.47</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>220.66</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>711.68</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>4062.50</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>221.00</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>743.17</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>130</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>4218.75</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>221.34</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>806.15</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>4437.50</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>221.72</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>862.83</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>4656.25</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>1.23</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>11.05</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>16</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>222.09</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>888.02</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>131</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>4750.00</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>1.29</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>11.23</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>222.47</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>913.22</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>5000.00</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>222.84</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>938.41</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>132</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>5281.25</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>1.19</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>10.93</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>223.22</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>963.60</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>133</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>5468.75</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>223.63</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>969.90</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>135</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>5625.00</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>14.59</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>224.03</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>976.20</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>136</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>5812.50</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>14.34</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>224.44</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>982.49</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>137</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>5906.25</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>14.08</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>1.17</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>10.87</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>224.84</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>1007.69</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>6093.75</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>13.57</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>20</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>225.25</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>6281.25</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>13.31</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>225.63</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>1013.98</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>139</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>6500.00</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>13.06</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>226.00</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>1020.28</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>140</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>6562.50</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>1.13</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>10.75</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>226.34</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>6687.50</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>22</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>226.66</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>141</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>6781.25</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>12.29</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>226.97</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>6875.00</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>227.28</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>143</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>6968.75</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>11.78</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>99.22</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>227.59</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>1001.39</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>7125.00</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>11.52</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>227.91</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>7187.50</td>
 </tr>
  <td height=20 class=xl6813801 style='height:15.0pt;border-top:none'>228.25</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>988.79</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>144</td>
  <td class=xl7013801 align=right style='border-top:none;border-left:none'>1.28</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>1.72</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>12.52</td>
  <td class=xl6813801 style='border-top:none;border-left:none'>10.59</td>
  <td class=xl6913801 style='border-top:none;border-left:none'>40</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>228.59</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>50.38</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>151</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>6187.50</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.32</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>14.33</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>40</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>228.94</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>69.28</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>5500.00</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>229.25</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>148</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>4875.00</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>229.59</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>147</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>4687.50</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.3</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>14.27</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>229.97</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>145</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>5250.00</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>3.07</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>16.58</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>230.31</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>144</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>4.77</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>21.70</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>230.69</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>143</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>5093.75</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>231.06</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>231.41</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>141</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>5000.00</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>231.78</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>140</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>4937.50</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>232.16</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>4906.25</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>232.56</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>139</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>4812.50</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>232.91</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>4750.00</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>233.28</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>137</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>233.66</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>198</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>4625.00</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>234.03</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>136</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>4593.75</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>234.41</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>234.78</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>4531.25</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>11.76</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>235.09</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>135</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>4562.50</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>4.08</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>19.62</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>235.41</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>4500.00</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.62</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>15.23</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>15.69</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>235.75</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>4437.50</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>236.06</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>4468.75</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.46</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>14.75</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>20.78</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>236.38</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>4375.00</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>1.93</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>13.16</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>22.75</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>236.72</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>94.47</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>4281.25</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>1.86</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>24.31</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>237.03</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>107.07</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>4312.50</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>25.88</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>237.34</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>125.96</td>
  <td class=xl6713801 align=right style='border-top:none;border-left:none'>2.56</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>27.06</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>237.66</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>138.56</td>
  <td class=xl6713801 align=right style='border-top:none;border-left:none'>2.82</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>28.24</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>237.97</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>157.45</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>28.63</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>36</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>238.31</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>170.05</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>4343.75</td>
  <td class=xl6713801 align=right style='border-top:none;border-left:none'>3.07</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>29.41</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>238.63</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>182.64</td>
  <td class=xl6713801 align=right style='border-top:none;border-left:none'>3.33</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>30.20</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>33</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>238.94</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>201.54</td>
  <td class=xl6713801 align=right style='border-top:none;border-left:none'>3.58</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.11</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>13.70</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>30.98</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>32</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>239.25</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>220.43</td>
  <td class=xl6713801 align=right style='border-top:none;border-left:none'>3.84</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>31.76</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>30</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>239.59</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>239.33</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.23</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>14.06</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>32.16</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>29</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>239.91</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>270.82</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>4406.25</td>
  <td class=xl6713801 align=right style='border-top:none;border-left:none'>4.61</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>28</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>240.22</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>289.71</td>
  <td class=xl6713801 align=right style='border-top:none;border-left:none'>5.12</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>32.55</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>240.53</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>308.60</td>
  <td class=xl6713801 align=right style='border-top:none;border-left:none'>5.38</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>240.84</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>321.20</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>26.27</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>241.19</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>195.24</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.36</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>14.45</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>241.50</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>4125.00</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>1.95</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>13.22</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>241.84</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>3531.25</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>26</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>242.22</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>3343.75</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>242.56</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>3468.75</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>242.91</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>19.61</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>243.25</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>3406.25</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>23.14</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>243.59</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>3437.50</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>243.94</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>119.66</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>244.28</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>34</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>244.63</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>151.15</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>29.02</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>244.97</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>163.75</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>29.80</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>245.28</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>245.63</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>30.59</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>245.97</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>188.94</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>246.28</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>246.63</td>
  <td class=xl6713801 align=right style='border-top:none;border-left:none'>4.35</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.21</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>14.00</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>246.94</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.25</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>247.28</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>247.59</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>247.94</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.42</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>14.63</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>248.28</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>176.35</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.38</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>27.45</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>248.63</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>248.94</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>26.67</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>249.28</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>249.59</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>144.85</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>249.94</td>
  <td class=xl6613801 style='border-top:none;border-left:none'>2.34</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>14.39</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>25.49</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>250.28</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>132.26</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>25.10</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>250.59</td>
  <td class=xl6513801 style='border-top:none;border-left:none'>24.71</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>250.94</td>
 </tr>
  <td height=20 class=xl6513801 style='height:15.0pt;border-top:none'>251.28</td>
 </tr>
 <![if supportMisalignedColumns]>
 <tr height=0 style='display:none'>
  <td width=64 style='width:48pt'></td>
  <td width=90 style='width:68pt'></td>
 </tr>
 <![endif]>
</table>
</div>
<!--END OF OUTPUT FROM EXCEL PUBLISH AS WEB PAGE WIZARD-->
</body>
</html>
