Cooling System Upgrades
Blurred Talon
2,307
44
Jan 2, 2004
Paradise, NL, Canada
With my FMIC about to go in and the fact that turbo motors generate a lot of heat, I want to do some cooling system upgrades.
I want to add an aluminum radiator, with a shroud and to slim fans. On the condenser I want to add a 10" fan and wire it as a pusher, to help push air through. I already plan to make FMIC ducting to force the air to flow through the FMIC followed by the condenser and then the radiator. Top it off with an RRE hood vent to suck some hot air out at speed.
Going to run stock thermostat and fan switch, 50/50 anti-freeze/water and some water wetter.
Opinions?
Should be more than enough. I have a 24x8x3 cored FMIC, stock radiator, AC, no heatshields or ceramic coatings (just the wastegate tube is wrapped), stock temp thermostat, and a 12" puller with shroud. With this setup I do not overheat. The only time it goes above 195* is if I'm in traffic for a while, and that's just until the fan kicks on. With that being said I have an aluminum radiator on the way, I'll be using my adjustable fan control setup once I take it off my truck, and I'm thinking about ditching the FMIC and going air/water. It never hurts to be over-prepared.
I wouldn't heat wrap a dd car..traps in moisture if u don't change them regularly.Got a link for ## fan/shrourd set up?
If you don't have clearance problems I would just use the stock fan on the pass. side and a slim fan on the driver's side. I don't have A/C but I only have the stock passenger's side fan and I never get above 200 with my FMIC and my aluminum radiator.
For being a stock fan they flow very well.
I was getting a bit of a cooling problem, My stock gauge would be fine autometer was going to 210 on the highway and link was saying 213 when the autometer gauge read 200.
So I made an air deflector that went on the core support to help make air go to the radiator tada workes great
Logically, you cant be running good temps on that setup.Your blocking all air flow to the radiator and cutting down to one fan.Im currently running the same setup and my temps get a little high at times in traffic.Not calling you a liar, but if you daily drive that car, I dont see how you could possibly not get any hotter than that.What type of gauge are you using?
Running just like Project, my scanmaster logger showed zero difference in the coolant temp sensor output in stop and go traffic in august. He's do nothign but remove the a/c fan that never activates unless you have a/c on. And he has no a/c
Take a look through this log and look at my coolant temps.
Code:
<html xmlns:o="urn:schemas-microsoft-com:office:office"
xmlns:x="urn:schemas-microsoft-com:office:excel"
xmlns="http://www.w3.org/TR/REC-html40">
<head>
<meta http-equiv=Content-Type content="text/html; charset=windows-1252">
<meta name=ProgId content=Excel.Sheet>
<meta name=Generator content="Microsoft Excel 10">
<link rel=File-List href="CoolantTemp_files/filelist.xml">
<style id="061009 to OPCC_24264_Styles"><!--table
	{mso-displayed-decimal-separator:"\.";
	mso-displayed-thousand-separator:"\,";}
.xl1524264
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:windowtext;
	font-size:10.0pt;
	font-weight:400;
	font-style:normal;
	text-decoration:none;
	font-family:Arial;
	mso-generic-font-family:auto;
	mso-font-charset:0;
	mso-number-format:General;
	text-align:general;
	vertical-align:bottom;
	mso-background-source:auto;
	mso-pattern:auto;
	white-space:nowrap;}
.xl2224264
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:windowtext;
	font-size:10.0pt;
	font-weight:400;
	font-style:normal;
	font-family:Arial;
	mso-font-charset:0;
	text-align:general;
	border:.5pt solid windowtext;
	mso-pattern:auto;
.xl2324264
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:windowtext;
	font-size:10.0pt;
	font-weight:700;
	font-style:normal;
	font-family:Arial, sans-serif;
	mso-font-charset:0;
	text-align:center;
	mso-pattern:auto;
.xl2424264
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:windowtext;
	font-size:10.0pt;
	font-weight:700;
	font-style:normal;
	mso-font-charset:0;
	text-align:general;
	mso-pattern:auto;
--></style>
</head>
<body>
<!--[if !excel]>&nbsp;&nbsp;<![endif]-->
<!--The following information was generated by Microsoft Excel's Publish as Web
Page wizard.-->
<!--If the same item is republished from Excel, all information between the DIV
tags will be replaced.-->
<!--START OF OUTPUT FROM EXCEL PUBLISH AS WEB PAGE WIZARD -->
<div id="061009 to OPCC_24264" align=center x:publishsource="Excel">
<table x:str border=0 cellpadding=0 cellspacing=0 width=579 style='border-collapse:
 collapse;table-layout:fixed;width:434pt'>
 <col width=64 span=8 style='width:48pt'>
 <col width=67 style='mso-width-source:userset;mso-width-alt:2450;width:50pt'>
 <tr height=17 style='height:12.75pt'>
  <td height=17 class=xl2424264 colspan=3 width=192 style='height:12.75pt;
  width:144pt'>TechnoMotive Datalogger</td>
  <td class=xl1524264 width=64 style='width:48pt'></td>
  <td class=xl1524264 width=67 style='width:50pt'></td>
 </tr>
  <td height=17 class=xl1524264 style='height:12.75pt'></td>
  <td class=xl1524264></td>
 </tr>
  <td height=17 class=xl2324264 style='height:12.75pt'>Time</td>
  <td class=xl2324264 style='border-left:none'>Airflow</td>
  <td class=xl2324264 style='border-left:none'>Coolant</td>
  <td class=xl2324264 style='border-left:none'>RPM</td>
  <td class=xl2324264 style='border-left:none'>IPW</td>
  <td class=xl2324264 style='border-left:none'>Knock</td>
  <td class=xl2324264 style='border-left:none'>O2v</td>
  <td class=xl2324264 style='border-left:none'>TPS</td>
  <td class=xl2324264 style='border-left:none'>Timing</td>
 </tr>
  <td height=17 class=xl2224264 align=right style='height:12.75pt;border-top:
  none' x:num>70.42</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>138.56</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>192</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2437.5</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3.84</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>0</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.52</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>32.55</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>28</td>
 </tr>
  none' x:num>70.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>151.15</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2468.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.54</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>27</td>
 </tr>
  none' x:num>71.07</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>157.45</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.46</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>30.2</td>
 </tr>
  none' x:num>71.39</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>144.85</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3.58</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.56</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>26.27</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>30</td>
 </tr>
  none' x:num>71.71</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>125.96</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2500</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3.07</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.48</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>25.49</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>31</td>
 </tr>
  none' x:num>72.03</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>119.66</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.81</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>24.31</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>32</td>
 </tr>
  none' x:num>72.35</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>107.07</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.44</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>23.53</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>33</td>
 </tr>
  none' x:num>72.67</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>100.77</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.7</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>23.14</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>34</td>
 </tr>
  none' x:num>72.98</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>94.47</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.82</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.58</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>22.75</td>
 </tr>
  none' x:num>73.3</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>22.35</td>
 </tr>
  none' x:num>73.62</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>88.17</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2531.25</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.64</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>21.57</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>35</td>
 </tr>
  none' x:num>73.94</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>81.87</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.3</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.25</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>18.82</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>36</td>
 </tr>
  none' x:num>74.26</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>62.98</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.79</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>17.65</td>
 </tr>
  none' x:num>74.57</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>56.68</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>15.29</td>
 </tr>
  none' x:num>74.89</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>50.38</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.54</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.89</td>
 </tr>
  none' x:num>75.2</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.91</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>14.9</td>
 </tr>
  none' x:num>75.52</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>44.09</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.36</td>
 </tr>
  none' x:num>75.84</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3.3</td>
 </tr>
  none' x:num>76.16</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.89</td>
 </tr>
  none' x:num>76.48</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2406.25</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.83</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>16.47</td>
 </tr>
  none' x:num>76.8</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.6</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>17.25</td>
 </tr>
  none' x:num>77.12</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>18.43</td>
 </tr>
  none' x:num>77.43</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2375</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.05</td>
 </tr>
  none' x:num>77.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.42</td>
 </tr>
  none' x:num>78.07</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>16.86</td>
 </tr>
  none' x:num>78.39</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2343.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>11.76</td>
 </tr>
  none' x:num>78.7</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>31.49</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2312.5</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.28</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>10.59</td>
 </tr>
  none' x:num>79.01</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2281.25</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.4</td>
 </tr>
  none' x:num>79.32</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.82</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>22</td>
 </tr>
  none' x:num>79.62</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>25.19</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2250</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>21</td>
 </tr>
  none' x:num>79.92</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2218.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4.47</td>
 </tr>
  none' x:num>80.22</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2187.5</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4.82</td>
 </tr>
  none' x:num>80.52</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2125</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>19</td>
 </tr>
  none' x:num>80.81</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1750</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>16</td>
 </tr>
  none' x:num>81.1</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1375</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>18</td>
 </tr>
  none' x:num>81.39</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>18.89</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1031.25</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>24</td>
 </tr>
  none' x:num>81.67</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1062.5</td>
 </tr>
  none' x:num>81.96</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1125</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4.04</td>
 </tr>
  none' x:num>82.25</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1156.25</td>
 </tr>
  none' x:num>82.55</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.23</td>
 </tr>
  none' x:num>82.84</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.15</td>
 </tr>
  none' x:num>83.12</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.13</td>
 </tr>
  none' x:num>83.41</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1093.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.21</td>
 </tr>
  none' x:num>83.69</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.34</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>20</td>
 </tr>
  none' x:num>83.97</td>
 </tr>
  none' x:num>84.25</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>968.75</td>
 </tr>
  none' x:num>84.53</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>937.5</td>
 </tr>
  none' x:num>84.81</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>906.25</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.62</td>
 </tr>
  none' x:num>85.08</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>843.75</td>
 </tr>
  none' x:num>85.36</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>15</td>
 </tr>
  none' x:num>85.64</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>14</td>
 </tr>
  none' x:num>85.92</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>12</td>
 </tr>
  none' x:num>86.19</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>875</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.77</td>
 </tr>
  none' x:num>86.47</td>
 </tr>
  none' x:num>86.75</td>
 </tr>
  none' x:num>87.03</td>
 </tr>
  none' x:num>87.31</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>13</td>
 </tr>
  none' x:num>87.58</td>
 </tr>
  none' x:num>87.86</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.5</td>
 </tr>
  none' x:num>88.14</td>
 </tr>
  none' x:num>88.42</td>
 </tr>
  none' x:num>88.69</td>
 </tr>
  none' x:num>88.97</td>
 </tr>
  none' x:num>89.25</td>
 </tr>
  none' x:num>89.53</td>
 </tr>
  none' x:num>89.8</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>781.25</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.71</td>
 </tr>
  none' x:num>90.08</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>812.5</td>
 </tr>
  none' x:num>90.35</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.68</td>
 </tr>
  none' x:num>90.63</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>11</td>
 </tr>
  none' x:num>90.91</td>
 </tr>
  none' x:num>91.19</td>
 </tr>
  none' x:num>91.47</td>
 </tr>
  none' x:num>91.74</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.66</td>
 </tr>
  none' x:num>92.02</td>
 </tr>
  none' x:num>92.3</td>
 </tr>
  none' x:num>92.58</td>
 </tr>
  none' x:num>92.85</td>
 </tr>
  none' x:num>93.13</td>
 </tr>
  none' x:num>93.41</td>
 </tr>
  none' x:num>93.69</td>
 </tr>
  none' x:num>93.97</td>
 </tr>
  none' x:num>94.24</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.38</td>
 </tr>
  none' x:num>94.52</td>
 </tr>
  none' x:num>94.8</td>
 </tr>
  none' x:num>95.08</td>
 </tr>
  none' x:num>95.36</td>
 </tr>
  none' x:num>95.64</td>
 </tr>
  none' x:num>95.91</td>
 </tr>
  none' x:num>96.19</td>
 </tr>
  none' x:num>96.47</td>
 </tr>
  none' x:num>96.75</td>
 </tr>
  none' x:num>97.03</td>
 </tr>
  none' x:num>97.3</td>
 </tr>
  none' x:num>97.58</td>
 </tr>
  none' x:num>97.86</td>
 </tr>
  none' x:num>98.13</td>
 </tr>
  none' x:num>98.41</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>10</td>
 </tr>
  none' x:num>98.69</td>
 </tr>
  none' x:num>98.97</td>
 </tr>
  none' x:num>99.24</td>
 </tr>
  none' x:num>99.52</td>
 </tr>
  none' x:num>99.8</td>
 </tr>
  none' x:num>100.08</td>
 </tr>
  none' x:num>100.36</td>
 </tr>
  none' x:num>100.64</td>
 </tr>
  none' x:num>100.92</td>
 </tr>
  none' x:num>101.2</td>
 </tr>
  none' x:num>101.47</td>
 </tr>
  none' x:num>101.75</td>
 </tr>
  none' x:num>102.03</td>
 </tr>
  none' x:num>102.31</td>
 </tr>
  none' x:num>102.59</td>
 </tr>
  none' x:num>102.87</td>
 </tr>
  none' x:num>103.14</td>
 </tr>
  none' x:num>103.42</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>19.22</td>
 </tr>
  none' x:num>103.71</td>
 </tr>
  none' x:num>103.99</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>37.79</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1312.5</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>16.08</td>
 </tr>
  none' x:num>104.28</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1406.25</td>
 </tr>
  none' x:num>104.58</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1437.5</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3.14</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>20.39</td>
 </tr>
  none' x:num>104.88</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>75.58</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1812.5</td>
 </tr>
  none' x:num>105.17</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1656.25</td>
 </tr>
  none' x:num>105.46</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1281.25</td>
 </tr>
  none' x:num>105.74</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1250</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>29</td>
 </tr>
  none' x:num>106.03</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1218.75</td>
 </tr>
  none' x:num>106.31</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>26</td>
 </tr>
  none' x:num>106.59</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>13.73</td>
 </tr>
  none' x:num>106.88</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>13.33</td>
 </tr>
  none' x:num>107.16</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1000</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.97</td>
 </tr>
  none' x:num>107.44</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3.16</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>18.04</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>17</td>
 </tr>
  none' x:num>107.73</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.93</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>12.55</td>
 </tr>
  none' x:num>108.01</td>
 </tr>
  none' x:num>108.3</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.27</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>23</td>
 </tr>
  none' x:num>108.58</td>
 </tr>
  none' x:num>108.87</td>
 </tr>
  none' x:num>109.15</td>
 </tr>
  none' x:num>109.43</td>
 </tr>
  none' x:num>109.71</td>
 </tr>
  none' x:num>109.99</td>
 </tr>
  none' x:num>110.26</td>
 </tr>
  none' x:num>110.54</td>
 </tr>
  none' x:num>110.82</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>195</td>
 </tr>
  none' x:num>111.1</td>
 </tr>
  none' x:num>111.38</td>
 </tr>
  none' x:num>111.66</td>
 </tr>
  none' x:num>111.94</td>
 </tr>
  none' x:num>112.22</td>
 </tr>
  none' x:num>112.49</td>
 </tr>
  none' x:num>112.77</td>
 </tr>
  none' x:num>113.05</td>
 </tr>
  none' x:num>113.33</td>
 </tr>
  none' x:num>113.61</td>
 </tr>
  none' x:num>113.88</td>
 </tr>
  none' x:num>114.16</td>
 </tr>
  none' x:num>114.44</td>
 </tr>
  none' x:num>114.72</td>
 </tr>
  none' x:num>115</td>
 </tr>
  none' x:num>115.28</td>
 </tr>
  none' x:num>115.55</td>
 </tr>
  none' x:num>115.83</td>
 </tr>
  none' x:num>116.11</td>
 </tr>
  none' x:num>116.39</td>
 </tr>
  none' x:num>116.66</td>
 </tr>
  none' x:num>116.94</td>
 </tr>
  none' x:num>117.23</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4.1</td>
 </tr>
  none' x:num>117.52</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1843.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.09</td>
 </tr>
  none' x:num>117.82</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1968.75</td>
 </tr>
  none' x:num>118.12</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1593.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.87</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>32.16</td>
 </tr>
  none' x:num>118.42</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1531.25</td>
 </tr>
  none' x:num>118.71</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1500</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>32.94</td>
 </tr>
  none' x:num>119.01</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>33.33</td>
 </tr>
  none' x:num>119.31</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4.35</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>34.51</td>
 </tr>
  none' x:num>119.61</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>132.26</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2062.5</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>35.69</td>
 </tr>
  none' x:num>119.93</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>36.08</td>
 </tr>
  none' x:num>120.25</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>188.94</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2750</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>34.12</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>25</td>
 </tr>
  none' x:num>120.56</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>214.13</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3093.75</td>
 </tr>
  none' x:num>120.86</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>226.73</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3406.25</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>31.76</td>
 </tr>
  none' x:num>121.14</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>233.03</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3656.25</td>
 </tr>
  none' x:num>121.43</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3718.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.93</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>40</td>
 </tr>
  none' x:num>121.74</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>69.28</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3281.25</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.17</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>38</td>
 </tr>
  none' x:num>122.07</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2812.5</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.01</td>
 </tr>
  none' x:num>122.39</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.68</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>25.1</td>
 </tr>
  none' x:num>122.71</td>
 </tr>
  none' x:num>123.02</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3.33</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>25.88</td>
 </tr>
  none' x:num>123.34</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>113.36</td>
 </tr>
  none' x:num>123.66</td>
 </tr>
  none' x:num>123.98</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>26.67</td>
 </tr>
  none' x:num>124.3</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2562.5</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>27.06</td>
 </tr>
  none' x:num>124.62</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2656.25</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>27.84</td>
 </tr>
  none' x:num>124.95</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2718.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.79</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>28.63</td>
 </tr>
  none' x:num>125.28</td>
 </tr>
  none' x:num>125.61</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>163.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2937.5</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>30.59</td>
 </tr>
  none' x:num>125.95</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>182.64</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3062.5</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>30.98</td>
 </tr>
  none' x:num>126.28</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3156.25</td>
 </tr>
  none' x:num>126.6</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>195.24</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>198</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3250</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.73</td>
 </tr>
  none' x:num>126.89</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>201.54</td>
 </tr>
  none' x:num>127.2</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>207.84</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3500</td>
 </tr>
  none' x:num>127.5</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3625</td>
 </tr>
  none' x:num>127.77</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3687.5</td>
 </tr>
  none' x:num>128.04</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3750</td>
 </tr>
  none' x:num>128.31</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3875</td>
 </tr>
  none' x:num>128.58</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3906.25</td>
 </tr>
  none' x:num>128.85</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>239.33</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4031.25</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4.61</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.78</td>
 </tr>
  none' x:num>129.13</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>245.62</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4093.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4.86</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.62</td>
 </tr>
  none' x:num>129.41</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>258.22</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4218.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.56</td>
 </tr>
  none' x:num>129.69</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>264.52</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4375</td>
 </tr>
  none' x:num>129.98</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>270.82</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4500</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.52</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>27.45</td>
 </tr>
  none' x:num>130.26</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4531.25</td>
 </tr>
  none' x:num>130.54</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.8</td>
 </tr>
  none' x:num>130.85</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>39</td>
 </tr>
  none' x:num>131.18</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3187.5</td>
 </tr>
  none' x:num>131.5</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3000</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>29.8</td>
 </tr>
  none' x:num>131.84</td>
 </tr>
  none' x:num>132.17</td>
 </tr>
  none' x:num>132.49</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>34.9</td>
 </tr>
  none' x:num>132.8</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3218.75</td>
 </tr>
  none' x:num>133.07</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>33.73</td>
 </tr>
  none' x:num>133.34</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3312.5</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>31.37</td>
 </tr>
  none' x:num>133.62</td>
 </tr>
  none' x:num>133.92</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3468.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>37</td>
 </tr>
  none' x:num>134.22</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3531.25</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.86</td>
 </tr>
  none' x:num>134.55</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>21.18</td>
 </tr>
  none' x:num>134.89</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3.18</td>
 </tr>
  none' x:num>135.21</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>21.96</td>
 </tr>
  none' x:num>135.52</td>
 </tr>
  none' x:num>135.84</td>
 </tr>
  none' x:num>136.15</td>
 </tr>
  none' x:num>136.46</td>
 </tr>
  none' x:num>136.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>23.92</td>
 </tr>
  none' x:num>137.06</td>
 </tr>
  none' x:num>137.36</td>
 </tr>
  none' x:num>137.65</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3562.5</td>
 </tr>
  none' x:num>137.94</td>
 </tr>
  none' x:num>138.23</td>
 </tr>
  none' x:num>138.54</td>
 </tr>
  none' x:num>138.83</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.85</td>
 </tr>
  none' x:num>139.13</td>
 </tr>
  none' x:num>139.42</td>
 </tr>
  none' x:num>139.7</td>
 </tr>
  none' x:num>139.99</td>
 </tr>
  none' x:num>140.27</td>
 </tr>
  none' x:num>140.56</td>
 </tr>
  none' x:num>140.87</td>
 </tr>
  none' x:num>141.17</td>
 </tr>
  none' x:num>141.46</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.91</td>
 </tr>
  none' x:num>141.77</td>
 </tr>
  none' x:num>142.08</td>
 </tr>
  none' x:num>142.38</td>
 </tr>
  none' x:num>142.68</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>20.78</td>
 </tr>
  none' x:num>143</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3437.5</td>
 </tr>
  none' x:num>143.32</td>
 </tr>
  none' x:num>143.63</td>
 </tr>
  none' x:num>143.94</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3343.75</td>
 </tr>
  none' x:num>144.25</td>
 </tr>
  none' x:num>144.58</td>
 </tr>
  none' x:num>144.91</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3.32</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>15.69</td>
 </tr>
  none' x:num>145.25</td>
 </tr>
  none' x:num>145.57</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>11.37</td>
 </tr>
  none' x:num>145.89</td>
 </tr>
  none' x:num>146.21</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3125</td>
 </tr>
  none' x:num>146.53</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.29</td>
 </tr>
  none' x:num>146.85</td>
 </tr>
  none' x:num>147.16</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3031.25</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4.63</td>
 </tr>
  none' x:num>147.47</td>
 </tr>
  none' x:num>147.78</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2968.75</td>
 </tr>
  none' x:num>148.1</td>
 </tr>
  none' x:num>148.41</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2906.25</td>
 </tr>
  none' x:num>148.72</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2843.75</td>
 </tr>
  none' x:num>149.03</td>
 </tr>
  none' x:num>149.34</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2625</td>
 </tr>
  none' x:num>149.65</td>
 </tr>
  none' x:num>149.95</td>
 </tr>
  none' x:num>150.24</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1781.25</td>
 </tr>
  none' x:num>150.53</td>
 </tr>
  none' x:num>150.81</td>
 </tr>
  none' x:num>151.1</td>
 </tr>
  none' x:num>151.39</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4.49</td>
 </tr>
  none' x:num>151.67</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1562.5</td>
 </tr>
  none' x:num>151.97</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3.24</td>
 </tr>
  none' x:num>152.27</td>
 </tr>
  none' x:num>152.57</td>
 </tr>
  none' x:num>152.87</td>
 </tr>
  none' x:num>153.17</td>
 </tr>
  none' x:num>153.46</td>
 </tr>
  none' x:num>153.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1906.25</td>
 </tr>
  none' x:num>154.04</td>
 </tr>
  none' x:num>154.33</td>
 </tr>
  none' x:num>154.62</td>
 </tr>
  none' x:num>154.92</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1687.5</td>
 </tr>
  none' x:num>155.22</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>14.51</td>
 </tr>
  none' x:num>155.52</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1625</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3.93</td>
 </tr>
  none' x:num>155.83</td>
 </tr>
  none' x:num>156.13</td>
 </tr>
  none' x:num>156.44</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1718.75</td>
 </tr>
  none' x:num>156.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.07</td>
 </tr>
  none' x:num>157.05</td>
 </tr>
  none' x:num>157.35</td>
 </tr>
  none' x:num>157.66</td>
 </tr>
  none' x:num>157.97</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2093.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>37.65</td>
 </tr>
  none' x:num>158.29</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2156.25</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>38.82</td>
 </tr>
  none' x:num>158.61</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>170.05</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>41.96</td>
 </tr>
  none' x:num>158.94</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>42.75</td>
 </tr>
  none' x:num>159.27</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>5.12</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>43.14</td>
 </tr>
  none' x:num>159.58</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2687.5</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>7.68</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.21</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>38.04</td>
 </tr>
  none' x:num>159.88</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>7.42</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.13</td>
 </tr>
  none' x:num>160.18</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>251.92</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>5.38</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>29.02</td>
 </tr>
  none' x:num>160.49</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>220.43</td>
 </tr>
  none' x:num>160.8</td>
 </tr>
  none' x:num>161.11</td>
 </tr>
  none' x:num>161.43</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3375</td>
 </tr>
  none' x:num>161.73</td>
 </tr>
  none' x:num>162.03</td>
 </tr>
  none' x:num>162.34</td>
 </tr>
  none' x:num>162.64</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3593.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>29.41</td>
 </tr>
  none' x:num>162.92</td>
 </tr>
  none' x:num>163.18</td>
 </tr>
  none' x:num>163.44</td>
 </tr>
  none' x:num>163.72</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3812.5</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>5.89</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.45</td>
 </tr>
  none' x:num>164</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>302.31</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>6.91</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.23</td>
 </tr>
  none' x:num>164.29</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>358.99</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4062.5</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>8.19</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.17</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>36.86</td>
 </tr>
  none' x:num>164.58</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>447.16</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4187.5</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>9.98</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>39.22</td>
 </tr>
  none' x:num>164.89</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>592.02</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4468.75</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>13.57</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>49.8</td>
 </tr>
  none' x:num>165.22</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>862.83</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4750</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>15.36</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.41</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>85.49</td>
 </tr>
  none' x:num>165.56</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>951</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>5187.5</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>15.1</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.31</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>89.8</td>
 </tr>
  none' x:num>165.91</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>988.79</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>5531.25</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>14.34</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.09</td>
 </tr>
  none' x:num>166.22</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>5468.75</td>
 </tr>
  none' x:num>166.5</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>5031.25</td>
 </tr>
  none' x:num>166.78</td>
 </tr>
  none' x:num>167.08</td>
 </tr>
  none' x:num>167.4</td>
 </tr>
  none' x:num>167.73</td>
 </tr>
  none' x:num>168.06</td>
 </tr>
  none' x:num>168.38</td>
 </tr>
  none' x:num>168.7</td>
 </tr>
  none' x:num>169.03</td>
 </tr>
  none' x:num>169.35</td>
 </tr>
  none' x:num>169.69</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.11</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>19.61</td>
 </tr>
  none' x:num>170.02</td>
 </tr>
  none' x:num>170.36</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>14.12</td>
 </tr>
  none' x:num>170.68</td>
 </tr>
  none' x:num>171</td>
 </tr>
  none' x:num>171.3</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2031.25</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3.03</td>
 </tr>
  none' x:num>171.61</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.97</td>
 </tr>
  none' x:num>171.92</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>24.71</td>
 </tr>
  none' x:num>172.24</td>
 </tr>
  none' x:num>172.55</td>
 </tr>
  none' x:num>172.86</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>28.24</td>
 </tr>
  none' x:num>173.17</td>
 </tr>
  none' x:num>173.48</td>
 </tr>
  none' x:num>173.79</td>
 </tr>
  none' x:num>174.09</td>
 </tr>
  none' x:num>174.4</td>
 </tr>
  none' x:num>174.7</td>
 </tr>
  none' x:num>175</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2000</td>
 </tr>
  none' x:num>175.29</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.7</td>
 </tr>
  none' x:num>175.59</td>
 </tr>
  none' x:num>175.88</td>
 </tr>
  none' x:num>176.18</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1875</td>
 </tr>
  none' x:num>176.46</td>
 </tr>
  none' x:num>176.75</td>
 </tr>
  none' x:num>177.03</td>
 </tr>
  none' x:num>177.32</td>
 </tr>
  none' x:num>177.6</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4.36</td>
 </tr>
  none' x:num>177.88</td>
 </tr>
  none' x:num>178.17</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>7</td>
 </tr>
  none' x:num>178.46</td>
 </tr>
  none' x:num>178.75</td>
 </tr>
  none' x:num>179.04</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3.54</td>
 </tr>
  none' x:num>179.33</td>
 </tr>
  none' x:num>179.64</td>
 </tr>
  none' x:num>179.94</td>
 </tr>
  none' x:num>180.25</td>
 </tr>
  none' x:num>180.55</td>
 </tr>
  none' x:num>180.85</td>
 </tr>
  none' x:num>181.14</td>
 </tr>
  none' x:num>181.43</td>
 </tr>
  none' x:num>181.72</td>
 </tr>
  none' x:num>182.01</td>
 </tr>
  none' x:num>182.3</td>
 </tr>
  none' x:num>182.59</td>
 </tr>
  none' x:num>182.89</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>12.16</td>
 </tr>
  none' x:num>183.19</td>
 </tr>
  none' x:num>183.49</td>
 </tr>
  none' x:num>183.79</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.95</td>
 </tr>
  none' x:num>184.1</td>
 </tr>
  none' x:num>184.41</td>
 </tr>
  none' x:num>184.71</td>
 </tr>
  none' x:num>185.01</td>
 </tr>
  none' x:num>185.31</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>10.98</td>
 </tr>
  none' x:num>185.61</td>
 </tr>
  none' x:num>185.91</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1.74</td>
 </tr>
  none' x:num>186.21</td>
 </tr>
  none' x:num>186.51</td>
 </tr>
  none' x:num>186.81</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3.22</td>
 </tr>
  none' x:num>187.1</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3.67</td>
 </tr>
  none' x:num>187.39</td>
 </tr>
  none' x:num>187.68</td>
 </tr>
  none' x:num>187.97</td>
 </tr>
  none' x:num>188.27</td>
 </tr>
  none' x:num>188.56</td>
 </tr>
  none' x:num>188.85</td>
 </tr>
  none' x:num>189.14</td>
 </tr>
  none' x:num>189.43</td>
 </tr>
  none' x:num>189.72</td>
 </tr>
  none' x:num>190.01</td>
 </tr>
  none' x:num>190.3</td>
 </tr>
  none' x:num>190.59</td>
 </tr>
  none' x:num>190.88</td>
 </tr>
  none' x:num>191.17</td>
 </tr>
  none' x:num>191.46</td>
 </tr>
  none' x:num>191.75</td>
 </tr>
  none' x:num>192.04</td>
 </tr>
  none' x:num>192.35</td>
 </tr>
  none' x:num>192.65</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4.38</td>
 </tr>
  none' x:num>192.95</td>
 </tr>
  none' x:num>193.26</td>
 </tr>
  none' x:num>193.56</td>
 </tr>
  none' x:num>193.87</td>
 </tr>
  none' x:num>194.17</td>
 </tr>
  none' x:num>194.47</td>
 </tr>
  none' x:num>194.77</td>
 </tr>
  none' x:num>195.07</td>
 </tr>
  none' x:num>195.37</td>
 </tr>
  none' x:num>195.67</td>
 </tr>
  none' x:num>195.97</td>
 </tr>
  none' x:num>196.27</td>
 </tr>
  none' x:num>196.58</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1937.5</td>
 </tr>
  none' x:num>196.88</td>
 </tr>
  none' x:num>197.18</td>
 </tr>
  none' x:num>197.49</td>
 </tr>
  none' x:num>197.79</td>
 </tr>
  none' x:num>198.09</td>
 </tr>
  none' x:num>198.39</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3.13</td>
 </tr>
  none' x:num>198.68</td>
 </tr>
  none' x:num>198.97</td>
 </tr>
  none' x:num>199.26</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>3.52</td>
 </tr>
  none' x:num>199.55</td>
 </tr>
  none' x:num>199.84</td>
 </tr>
  none' x:num>200.13</td>
 </tr>
  none' x:num>200.42</td>
 </tr>
  none' x:num>200.71</td>
 </tr>
  none' x:num>201</td>
 </tr>
  none' x:num>201.3</td>
 </tr>
  none' x:num>201.59</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1468.75</td>
 </tr>
  none' x:num>201.89</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>4.06</td>
 </tr>
  none' x:num>202.19</td>
 </tr>
  none' x:num>202.48</td>
 </tr>
  none' x:num>202.78</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1343.75</td>
 </tr>
  none' x:num>203.07</td>
 </tr>
  none' x:num>203.36</td>
 </tr>
  none' x:num>203.65</td>
 </tr>
  none' x:num>203.94</td>
 </tr>
  none' x:num>204.22</td>
 </tr>
  none' x:num>204.51</td>
 </tr>
  none' x:num>204.8</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>1187.5</td>
 </tr>
  none' x:num>205.09</td>
 </tr>
  none' x:num>205.37</td>
 </tr>
  none' x:num>205.66</td>
 </tr>
  none' x:num>205.95</td>
 </tr>
  none' x:num>206.23</td>
 </tr>
  none' x:num>206.52</td>
 </tr>
  none' x:num>206.8</td>
 </tr>
  none' x:num>207.08</td>
 </tr>
  none' x:num>207.37</td>
 </tr>
  none' x:num>207.65</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>2.32</td>
 </tr>
  none' x:num>207.93</td>
 </tr>
  none' x:num>208.22</td>
 </tr>
  none' x:num>208.5</td>
 </tr>
  none' x:num>208.78</td>
 </tr>
  none' x:num>209.05</td>
 </tr>
  none' x:num>209.33</td>
 </tr>
  none' x:num>209.61</td>
 </tr>
  none' x:num>209.89</td>
 </tr>
  none' x:num>210.16</td>
 </tr>
  none' x:num>210.44</td>
 </tr>
  none' x:num>210.71</td>
 </tr>
  none' x:num>210.99</td>
 </tr>
  none' x:num>211.27</td>
 </tr>
  none' x:num>211.55</td>
 </tr>
  none' x:num>211.83</td>
 </tr>
  none' x:num>212.11</td>
 </tr>
  none' x:num>212.39</td>
  <td class=xl2224264 align=right style='border-top:none;border-left:none' x:num>12.94</td>
 </tr>
  none' x:num>212.67</td>
 </tr>
  none' x:num>212.95</td>
 </tr>
  none' x:num>213.23</td>
 </tr>
  none' x:num>213.51</td>
 </tr>
  none' x:num>213.79</td>
 </tr>
  none' x:num>214.07</td>
 </tr>
  none' x:num>214.35</td>
 </tr>
  none' x:num>214.63</td>
 </tr>
  none' x:num>214.9</td>
 </tr>
  none' x:num>215.18</td>
 </tr>
  none' x:num>215.46</td>
 </tr>
  none' x:num>215.73</td>
 </tr>
  none' x:num>216.01</td>
 </tr>
  none' x:num>216.29</td>
 </tr>
  none' x:num>216.56</td>
 </tr>
  none' x:num>216.84</td>
 </tr>
  none' x:num>217.11</td>
 </tr>
  none' x:num>217.39</td>
 </tr>
  none' x:num>217.66</td>
 </tr>
  none' x:num>217.94</td>
 </tr>
  none' x:num>218.22</td>
 </tr>
  none' x:num>218.49</td>
 </tr>
  none' x:num>218.77</td>
 </tr>
  none' x:num>219.05</td>
 </tr>
  none' x:num>219.33</td>
 </tr>
  none' x:num>219.61</td>
 </tr>
  none' x:num>219.89</td>
 </tr>
  none' x:num>220.16</td>
 </tr>
  none' x:num>220.44</td>
 </tr>
  none' x:num>220.72</td>
 </tr>
  none' x:num>221</td>
 </tr>
  none' x:num>221.28</td>
 </tr>
  none' x:num>221.56</td>
 </tr>
  none' x:num>221.84</td>
 </tr>
  none' x:num>222.12</td>
 </tr>
  none' x:num>222.39</td>
 </tr>
  none' x:num>222.67</td>
 </tr>
  none' x:num>222.95</td>
 </tr>
  none' x:num>223.23</td>
 </tr>
  none' x:num>223.51</td>
 </tr>
  none' x:num>223.78</td>
 </tr>
  none' x:num>224.06</td>
 </tr>
  none' x:num>224.34</td>
 </tr>
  none' x:num>224.62</td>
 </tr>
  none' x:num>224.89</td>
 </tr>
  none' x:num>225.17</td>
 </tr>
  none' x:num>225.45</td>
 </tr>
  none' x:num>225.73</td>
 </tr>
  none' x:num>226</td>
 </tr>
  none' x:num>226.28</td>
 </tr>
  none' x:num>226.56</td>
 </tr>
  none' x:num>226.84</td>
 </tr>
  none' x:num>227.12</td>
 </tr>
  none' x:num>227.4</td>
 </tr>
  none' x:num>227.68</td>
 </tr>
  none' x:num>227.96</td>
 </tr>
  none' x:num>228.23</td>
 </tr>
  none' x:num>228.51</td>
 </tr>
  none' x:num>228.79</td>
 </tr>
  none' x:num>229.07</td>
 </tr>
  none' x:num>229.35</td>
 </tr>
  none' x:num>229.63</td>
 </tr>
  none' x:num>229.91</td>
 </tr>
  none' x:num>230.18</td>
 </tr>
  none' x:num>230.46</td>
 </tr>
  none' x:num>230.74</td>
 </tr>
 <![if supportMisalignedColumns]>
 <tr height=0 style='display:none'>
  <td width=64 style='width:48pt'></td>
  <td width=67 style='width:50pt'></td>
 </tr>
 <![endif]>
</table>
</div>
<!--END OF OUTPUT FROM EXCEL PUBLISH AS WEB PAGE WIZARD-->
</body>
</html>
And here's how much my FMIC covers up my radiator:
Thats crazy.Maybe mine does that cause its set up a little different? I have a bigger core and its on the 2g so there really is insufficiant airflow to the radiator..I bought a aluminum radiator and that definitly helped but I need some shrouds and a couple slim fans.Im well aware of how the a/c fan works, but I figured since there is a lavk of air to the front of the radiator, any air would help.You radiator definitly is getting more air than mine..LOL.But good for you either way..
Just something I noticed... I have a brand new OEM radiator with no ducting, no hood vents, etc. My temps were high until I put in a 170 degree tstat from napa and temps dropped from ~206 to 180 (with the coolant offset sent to +20 in dsmlink so the fans come on earlier)... this is on stock fans too. ETS front mount. AC fan wired to come on with the main fan..So if you want even cooler you could try a lower temp t stat.
very good idea nofear, i will be going to napa the next few days and buying meself a new lower degree t stat, can i ask how you guys wire the AC fan to come on when the main fan comes on? and couldnt you somehow make a duct from where the old SMIC was and route it twords the radiator?
New Page
I basically just used the diagram at the bottom of that page to do it. I didn't put the manual switch in though.
How about a log from a 3rd gear pull?Im more interested in those coolant temps.Idle temps don't completly show how effective or not effective your cooling system is.
Here ya go!! :thumb:
The 100% throttle is a 3rd gear pull of me getting on the highway. The car had been running for about 30 minutes prior from me going from one job to Home to change. Then, from Home to Panda Express then from PE to my other job. The log was done from PE to my other job.
Enjoy!
Code:
<head>
<link rel=File-List href="Page_files/filelist.xml">
<style id="3rd Gear Pull2_9623_Styles">
<!--table
.xl159623
	{padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:windowtext;
	font-size:10.0pt;
	font-weight:400;
	font-style:normal;
	font-family:Arial;
	mso-font-charset:0;
	text-align:general;
	mso-pattern:auto;
</style>
</head>
<body>
Page wizard.-->
<div id="3rd Gear Pull2_9623" align=center x:publishsource="Excel">
<table x:str border=0 cellpadding=0 cellspacing=0 width=576 style='border-collapse:
 collapse;table-layout:fixed;width:432pt'>
 <col width=64 span=9 style='width:48pt'>
  <td height=17 class=xl159623 colspan=3 width=192 style='height:12.75pt;
  <td class=xl159623 width=64 style='width:48pt'></td>
 </tr>
  <td height=17 class=xl159623 style='height:12.75pt'></td>
  <td class=xl159623></td>
 </tr>
  <td height=17 class=xl159623 style='height:12.75pt'>Time</td>
  <td class=xl159623>AirFlow</td>
  <td class=xl159623>Coolant</td>
  <td class=xl159623>RPM</td>
  <td class=xl159623>IPW</td>
  <td class=xl159623>Knock</td>
  <td class=xl159623>O2v</td>
  <td class=xl159623>TPS</td>
  <td class=xl159623>Timing</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>146.23</td>
  <td class=xl159623 align=right x:num>31.49</td>
  <td class=xl159623 align=right x:num>195</td>
  <td class=xl159623 align=right x:num>2687.5</td>
  <td class=xl159623 align=right x:num>1.28</td>
  <td class=xl159623 align=right x:num>0</td>
  <td class=xl159623 align=right x:num>2.19</td>
  <td class=xl159623 align=right x:num>10.59</td>
  <td class=xl159623 align=right x:num>37</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>146.54</td>
  <td class=xl159623 align=right x:num>25.19</td>
  <td class=xl159623 align=right x:num>2656.25</td>
  <td class=xl159623 align=right x:num>2.79</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>146.85</td>
  <td class=xl159623 align=right x:num>2625</td>
  <td class=xl159623 align=right x:num>3.34</td>
  <td class=xl159623 align=right x:num>24</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>147.15</td>
  <td class=xl159623 align=right x:num>2593.75</td>
  <td class=xl159623 align=right x:num>3.44</td>
  <td class=xl159623 align=right x:num>23</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>147.45</td>
  <td class=xl159623 align=right x:num>2562.5</td>
  <td class=xl159623 align=right x:num>4.84</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>147.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>148.05</td>
  <td class=xl159623 align=right x:num>2500</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>148.35</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>148.65</td>
  <td class=xl159623 align=right x:num>2437.5</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>148.95</td>
  <td class=xl159623 align=right x:num>13.33</td>
  <td class=xl159623 align=right x:num>35</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>149.27</td>
  <td class=xl159623 align=right x:num>1.54</td>
  <td class=xl159623 align=right x:num>17.25</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>149.59</td>
  <td class=xl159623 align=right x:num>50.38</td>
  <td class=xl159623 align=right x:num>2406.25</td>
  <td class=xl159623 align=right x:num>2.05</td>
  <td class=xl159623 align=right x:num>3.38</td>
  <td class=xl159623 align=right x:num>19.22</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>149.91</td>
  <td class=xl159623 align=right x:num>62.98</td>
  <td class=xl159623 align=right x:num>2.62</td>
  <td class=xl159623 align=right x:num>20.39</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>150.23</td>
  <td class=xl159623 align=right x:num>69.28</td>
  <td class=xl159623 align=right x:num>2.3</td>
  <td class=xl159623 align=right x:num>2.46</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>150.55</td>
  <td class=xl159623 align=right x:num>75.58</td>
  <td class=xl159623 align=right x:num>2.34</td>
  <td class=xl159623 align=right x:num>20.78</td>
  <td class=xl159623 align=right x:num>36</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>150.87</td>
  <td class=xl159623 align=right x:num>2468.75</td>
  <td class=xl159623 align=right x:num>2.4</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>151.19</td>
  <td class=xl159623 align=right x:num>2.66</td>
  <td class=xl159623 align=right x:num>21.18</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>151.5</td>
  <td class=xl159623 align=right x:num>81.87</td>
  <td class=xl159623 align=right x:num>2.54</td>
  <td class=xl159623 align=right x:num>23.14</td>
  <td class=xl159623 align=right x:num>34</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>151.82</td>
  <td class=xl159623 align=right x:num>94.47</td>
  <td class=xl159623 align=right x:num>2531.25</td>
  <td class=xl159623 align=right x:num>2.82</td>
  <td class=xl159623 align=right x:num>2.42</td>
  <td class=xl159623 align=right x:num>24.31</td>
  <td class=xl159623 align=right x:num>33</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>152.14</td>
  <td class=xl159623 align=right x:num>100.77</td>
  <td class=xl159623 align=right x:num>2.48</td>
  <td class=xl159623 align=right x:num>27.06</td>
  <td class=xl159623 align=right x:num>32</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>152.46</td>
  <td class=xl159623 align=right x:num>119.66</td>
  <td class=xl159623 align=right x:num>3.33</td>
  <td class=xl159623 align=right x:num>30.98</td>
  <td class=xl159623 align=right x:num>30</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>152.78</td>
  <td class=xl159623 align=right x:num>144.85</td>
  <td class=xl159623 align=right x:num>3.84</td>
  <td class=xl159623 align=right x:num>32.55</td>
  <td class=xl159623 align=right x:num>28</td>
 </tr>
 <tr height=17 style='height:12.75pt'>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>153.1</td>
  <td class=xl159623 align=right x:num>157.45</td>
  <td class=xl159623 align=right x:num>36.47</td>
  <td class=xl159623 align=right x:num>25</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>153.42</td>
  <td class=xl159623 align=right x:num>182.64</td>
  <td class=xl159623 align=right x:num>2750</td>
  <td class=xl159623 align=right x:num>4.1</td>
  <td class=xl159623 align=right x:num>38.04</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>153.75</td>
  <td class=xl159623 align=right x:num>195.24</td>
  <td class=xl159623 align=right x:num>2781.25</td>
  <td class=xl159623 align=right x:num>4.35</td>
  <td class=xl159623 align=right x:num>2.6</td>
  <td class=xl159623 align=right x:num>39.61</td>
  <td class=xl159623 align=right x:num>22</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>154.08</td>
  <td class=xl159623 align=right x:num>220.43</td>
  <td class=xl159623 align=right x:num>2875</td>
  <td class=xl159623 align=right x:num>4.86</td>
  <td class=xl159623 align=right x:num>40.78</td>
  <td class=xl159623 align=right x:num>21</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>154.4</td>
  <td class=xl159623 align=right x:num>239.33</td>
  <td class=xl159623 align=right x:num>2906.25</td>
  <td class=xl159623 align=right x:num>2.58</td>
  <td class=xl159623 align=right x:num>41.18</td>
  <td class=xl159623 align=right x:num>20</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>154.71</td>
  <td class=xl159623 align=right x:num>258.22</td>
  <td class=xl159623 align=right x:num>2968.75</td>
  <td class=xl159623 align=right x:num>5.38</td>
  <td class=xl159623 align=right x:num>41.57</td>
  <td class=xl159623 align=right x:num>19</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>155.01</td>
  <td class=xl159623 align=right x:num>283.41</td>
  <td class=xl159623 align=right x:num>3031.25</td>
  <td class=xl159623 align=right x:num>7.68</td>
  <td class=xl159623 align=right x:num>1.19</td>
  <td class=xl159623 align=right x:num>42.35</td>
  <td class=xl159623 align=right x:num>18</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>155.28</td>
  <td class=xl159623 align=right x:num>308.6</td>
  <td class=xl159623 align=right x:num>3125</td>
  <td class=xl159623 align=right x:num>8.45</td>
  <td class=xl159623 align=right x:num>1.13</td>
  <td class=xl159623 align=right x:num>45.88</td>
  <td class=xl159623 align=right x:num>17</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>155.56</td>
  <td class=xl159623 align=right x:num>346.39</td>
  <td class=xl159623 align=right x:num>3187.5</td>
  <td class=xl159623 align=right x:num>9.22</td>
  <td class=xl159623 align=right x:num>0.92</td>
  <td class=xl159623 align=right x:num>50.59</td>
  <td class=xl159623 align=right x:num>16</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>155.83</td>
  <td class=xl159623 align=right x:num>396.78</td>
  <td class=xl159623 align=right x:num>3281.25</td>
  <td class=xl159623 align=right x:num>10.75</td>
  <td class=xl159623 align=right x:num>0.9</td>
  <td class=xl159623 align=right x:num>58.04</td>
  <td class=xl159623 align=right x:num>14</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>156.11</td>
  <td class=xl159623 align=right x:num>478.65</td>
  <td class=xl159623 align=right x:num>3375</td>
  <td class=xl159623 align=right x:num>12.54</td>
  <td class=xl159623 align=right x:num>1</td>
  <td class=xl159623 align=right x:num>71.37</td>
  <td class=xl159623 align=right x:num>13</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>156.39</td>
  <td class=xl159623 align=right x:num>579.42</td>
  <td class=xl159623 align=right x:num>3500</td>
  <td class=xl159623 align=right x:num>14.34</td>
  <td class=xl159623 align=right x:num>1.05</td>
  <td class=xl159623 align=right x:num>78.82</td>
  <td class=xl159623 align=right x:num>12</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>156.68</td>
  <td class=xl159623 align=right x:num>636.1</td>
  <td class=xl159623 align=right x:num>3625</td>
  <td class=xl159623 align=right x:num>14.08</td>
  <td class=xl159623 align=right x:num>100</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>156.97</td>
  <td class=xl159623 align=right x:num>648.7</td>
  <td class=xl159623 align=right x:num>3781.25</td>
  <td class=xl159623 align=right x:num>1.48</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>157.26</td>
  <td class=xl159623 align=right x:num>686.49</td>
  <td class=xl159623 align=right x:num>3937.5</td>
  <td class=xl159623 align=right x:num>1.11</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>157.56</td>
  <td class=xl159623 align=right x:num>717.98</td>
  <td class=xl159623 align=right x:num>4093.75</td>
  <td class=xl159623 align=right x:num>1.07</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>157.86</td>
  <td class=xl159623 align=right x:num>749.47</td>
  <td class=xl159623 align=right x:num>4218.75</td>
  <td class=xl159623 align=right x:num>14.59</td>
  <td class=xl159623 align=right x:num>1.09</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>158.18</td>
  <td class=xl159623 align=right x:num>793.55</td>
  <td class=xl159623 align=right x:num>4468.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>158.5</td>
  <td class=xl159623 align=right x:num>843.94</td>
  <td class=xl159623 align=right x:num>4593.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>158.83</td>
  <td class=xl159623 align=right x:num>869.13</td>
  <td class=xl159623 align=right x:num>4718.75</td>
  <td class=xl159623 align=right x:num>1.15</td>
  <td class=xl159623 align=right x:num>15</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>159.16</td>
  <td class=xl159623 align=right x:num>881.73</td>
  <td class=xl159623 align=right x:num>4906.25</td>
  <td class=xl159623 align=right x:num>1.17</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>159.49</td>
  <td class=xl159623 align=right x:num>900.62</td>
  <td class=xl159623 align=right x:num>5031.25</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>159.83</td>
  <td class=xl159623 align=right x:num>932.11</td>
  <td class=xl159623 align=right x:num>5187.5</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>160.17</td>
  <td class=xl159623 align=right x:num>944.71</td>
  <td class=xl159623 align=right x:num>5437.5</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>160.52</td>
  <td class=xl159623 align=right x:num>951</td>
  <td class=xl159623 align=right x:num>5593.75</td>
  <td class=xl159623 align=right x:num>13.82</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>160.88</td>
  <td class=xl159623 align=right x:num>963.6</td>
  <td class=xl159623 align=right x:num>5750</td>
  <td class=xl159623 align=right x:num>13.57</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>161.22</td>
  <td class=xl159623 align=right x:num>976.2</td>
  <td class=xl159623 align=right x:num>5781.25</td>
  <td class=xl159623 align=right x:num>1.25</td>
  <td class=xl159623 align=right x:num>40</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>161.52</td>
  <td class=xl159623 align=right x:num>56.68</td>
  <td class=xl159623 align=right x:num>5468.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>161.8</td>
  <td class=xl159623 align=right x:num>4843.75</td>
  <td class=xl159623 align=right x:num>2.56</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>162.08</td>
  <td class=xl159623 align=right x:num>4250</td>
  <td class=xl159623 align=right x:num>1.79</td>
  <td class=xl159623 align=right x:num>2.07</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>162.36</td>
  <td class=xl159623 align=right x:num>4281.25</td>
  <td class=xl159623 align=right x:num>1.8</td>
  <td class=xl159623 align=right x:num>28.63</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>162.64</td>
  <td class=xl159623 align=right x:num>170.05</td>
  <td class=xl159623 align=right x:num>3.07</td>
  <td class=xl159623 align=right x:num>1.45</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>162.92</td>
  <td class=xl159623 align=right x:num>176.35</td>
  <td class=xl159623 align=right x:num>4312.5</td>
  <td class=xl159623 align=right x:num>1.58</td>
  <td class=xl159623 align=right x:num>28.24</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>163.21</td>
  <td class=xl159623 align=right x:num>1.6</td>
  <td class=xl159623 align=right x:num>21.96</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>163.48</td>
  <td class=xl159623 align=right x:num>107.07</td>
  <td class=xl159623 align=right x:num>1.68</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>163.76</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>164.03</td>
  <td class=xl159623 align=right x:num>2.09</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>164.3</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>164.57</td>
  <td class=xl159623 align=right x:num>2.91</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>164.83</td>
  <td class=xl159623 align=right x:num>4156.25</td>
  <td class=xl159623 align=right x:num>2.52</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>165.11</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>165.38</td>
  <td class=xl159623 align=right x:num>4125</td>
  <td class=xl159623 align=right x:num>2.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>165.65</td>
  <td class=xl159623 align=right x:num>4062.5</td>
  <td class=xl159623 align=right x:num>18.82</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>165.93</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>166.24</td>
  <td class=xl159623 align=right x:num>44.09</td>
  <td class=xl159623 align=right x:num>3.55</td>
  <td class=xl159623 align=right x:num>39</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>166.57</td>
  <td class=xl159623 align=right x:num>37.79</td>
  <td class=xl159623 align=right x:num>3156.25</td>
  <td class=xl159623 align=right x:num>3.32</td>
  <td class=xl159623 align=right x:num>12.55</td>
  <td class=xl159623 align=right x:num>38</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>166.89</td>
  <td class=xl159623 align=right x:num>18.04</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>167.22</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>167.55</td>
  <td class=xl159623 align=right x:num>3218.75</td>
  <td class=xl159623 align=right x:num>2.44</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>167.89</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>168.22</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>168.55</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>168.88</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>169.21</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>169.55</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>169.88</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>170.21</td>
  <td class=xl159623 align=right x:num>2.64</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>170.54</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>170.87</td>
  <td class=xl159623 align=right x:num>3093.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>171.2</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>171.53</td>
  <td class=xl159623 align=right x:num>2.68</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>171.86</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>172.19</td>
  <td class=xl159623 align=right x:num>3062.5</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>172.52</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>172.85</td>
  <td class=xl159623 align=right x:num>2.32</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>173.18</td>
  <td class=xl159623 align=right x:num>2.5</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>173.5</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>173.83</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>174.15</td>
  <td class=xl159623 align=right x:num>3000</td>
  <td class=xl159623 align=right x:num>2.38</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>174.47</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>174.79</td>
  <td class=xl159623 align=right x:num>2.7</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>175.12</td>
  <td class=xl159623 align=right x:num>2.36</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>175.44</td>
  <td class=xl159623 align=right x:num>2937.5</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>175.77</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>176.1</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>176.42</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>176.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>177.07</td>
  <td class=xl159623 align=right x:num>198</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>177.4</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>177.73</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>178.05</td>
  <td class=xl159623 align=right x:num>19.61</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>178.38</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>178.7</td>
  <td class=xl159623 align=right x:num>2843.75</td>
  <td class=xl159623 align=right x:num>22.35</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>179.03</td>
  <td class=xl159623 align=right x:num>88.17</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>179.36</td>
  <td class=xl159623 align=right x:num>23.53</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>179.68</td>
  <td class=xl159623 align=right x:num>23.92</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>180.01</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>180.34</td>
  <td class=xl159623 align=right x:num>24.71</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>180.66</td>
  <td class=xl159623 align=right x:num>113.36</td>
  <td class=xl159623 align=right x:num>27.84</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>180.99</td>
  <td class=xl159623 align=right x:num>132.26</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>181.32</td>
  <td class=xl159623 align=right x:num>2.71</td>
  <td class=xl159623 align=right x:num>33.73</td>
  <td class=xl159623 align=right x:num>27</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>181.65</td>
  <td class=xl159623 align=right x:num>36.08</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>181.98</td>
  <td class=xl159623 align=right x:num>201.54</td>
  <td class=xl159623 align=right x:num>36.86</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>182.31</td>
  <td class=xl159623 align=right x:num>4.61</td>
  <td class=xl159623 align=right x:num>37.25</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>182.63</td>
  <td class=xl159623 align=right x:num>233.03</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>182.96</td>
  <td class=xl159623 align=right x:num>245.62</td>
  <td class=xl159623 align=right x:num>5.12</td>
  <td class=xl159623 align=right x:num>43.14</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>183.26</td>
  <td class=xl159623 align=right x:num>7.94</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>183.56</td>
  <td class=xl159623 align=right x:num>314.9</td>
  <td class=xl159623 align=right x:num>8.7</td>
  <td class=xl159623 align=right x:num>0.96</td>
  <td class=xl159623 align=right x:num>48.24</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>183.85</td>
  <td class=xl159623 align=right x:num>9.73</td>
  <td class=xl159623 align=right x:num>0.94</td>
  <td class=xl159623 align=right x:num>48.63</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>184.12</td>
  <td class=xl159623 align=right x:num>377.88</td>
  <td class=xl159623 align=right x:num>10.5</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>184.39</td>
  <td class=xl159623 align=right x:num>390.48</td>
  <td class=xl159623 align=right x:num>9.98</td>
  <td class=xl159623 align=right x:num>0.84</td>
  <td class=xl159623 align=right x:num>33.33</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>184.66</td>
  <td class=xl159623 align=right x:num>340.09</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>184.96</td>
  <td class=xl159623 align=right x:num>3.58</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>185.26</td>
  <td class=xl159623 align=right x:num>26</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>185.58</td>
  <td class=xl159623 align=right x:num>29</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>185.91</td>
  <td class=xl159623 align=right x:num>1.41</td>
  <td class=xl159623 align=right x:num>16.47</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>186.24</td>
  <td class=xl159623 align=right x:num>1.33</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>186.57</td>
  <td class=xl159623 align=right x:num>1.74</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>186.89</td>
  <td class=xl159623 align=right x:num>12.94</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>187.22</td>
  <td class=xl159623 align=right x:num>15.29</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>187.55</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>187.88</td>
  <td class=xl159623 align=right x:num>2.97</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>188.2</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>188.53</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>188.86</td>
  <td class=xl159623 align=right x:num>125.96</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>189.19</td>
  <td class=xl159623 align=right x:num>138.56</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>189.51</td>
  <td class=xl159623 align=right x:num>31</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>189.84</td>
  <td class=xl159623 align=right x:num>151.15</td>
  <td class=xl159623 align=right x:num>29.02</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>190.17</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>190.49</td>
  <td class=xl159623 align=right x:num>163.75</td>
  <td class=xl159623 align=right x:num>29.41</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>190.82</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>191.15</td>
  <td class=xl159623 align=right x:num>29.8</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>191.48</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>191.81</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>192.14</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>192.47</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>192.8</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>193.14</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>193.47</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>193.8</td>
  <td class=xl159623 align=right x:num>26.67</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>194.13</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>194.47</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>194.81</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>195.14</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>195.48</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>195.81</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>196.14</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>196.47</td>
  <td class=xl159623 align=right x:num>27.45</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>196.8</td>
  <td class=xl159623 align=right x:num>2.73</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>197.12</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>197.45</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>197.77</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>198.1</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>198.43</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>198.76</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>199.1</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>199.43</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>199.76</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>200.09</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>200.42</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>200.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>201.09</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>201.42</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>201.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>202.09</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>202.42</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>202.76</td>
  <td class=xl159623 align=right x:num>3250</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>203.09</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>203.42</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>203.76</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>204.1</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>204.43</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>204.77</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>205.11</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>205.44</td>
  <td class=xl159623 align=right x:num>15.69</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>205.77</td>
  <td class=xl159623 align=right x:num>1.99</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>206.1</td>
  <td class=xl159623 align=right x:num>1.5</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>206.43</td>
  <td class=xl159623 align=right x:num>1.72</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>206.76</td>
  <td class=xl159623 align=right x:num>2.89</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>207.09</td>
  <td class=xl159623 align=right x:num>3.05</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>207.42</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>207.76</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>208.09</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>208.42</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>208.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>209.08</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>209.42</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>209.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>210.08</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>210.41</td>
  <td class=xl159623 align=right x:num>22.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>210.74</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>211.07</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>211.4</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>211.72</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>212.04</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>212.36</td>
  <td class=xl159623 align=right x:num>21.57</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>212.69</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>213.01</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>213.34</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>213.67</td>
  <td class=xl159623 align=right x:num>25.1</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>214</td>
  <td class=xl159623 align=right x:num>25.88</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>214.33</td>
  <td class=xl159623 align=right x:num>26.27</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>214.66</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>214.99</td>
  <td class=xl159623 align=right x:num>2.77</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>215.33</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>215.66</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>215.99</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>216.32</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>216.65</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>216.98</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>217.31</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>217.64</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>217.97</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>218.29</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>218.62</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>218.95</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>219.28</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>219.61</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>219.93</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>220.26</td>
  <td class=xl159623 align=right x:num>18.43</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>220.59</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>220.91</td>
  <td class=xl159623 align=right x:num>2.13</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>221.22</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>221.53</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>221.84</td>
  <td class=xl159623 align=right x:num>3.52</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>222.15</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>222.46</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>222.76</td>
  <td class=xl159623 align=right x:num>2812.5</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>223.07</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>223.38</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>223.68</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>223.99</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>224.29</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>224.6</td>
  <td class=xl159623 align=right x:num>2718.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>224.91</td>
  <td class=xl159623 align=right x:num>11.37</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>225.23</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>225.55</td>
  <td class=xl159623 align=right x:num>14.12</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>225.88</td>
  <td class=xl159623 align=right x:num>4.8</td>
  <td class=xl159623 align=right x:num>16.86</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>226.21</td>
  <td class=xl159623 align=right x:num>3.36</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>226.53</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>226.86</td>
  <td class=xl159623 align=right x:num>2.17</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>227.19</td>
  <td class=xl159623 align=right x:num>2.25</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>227.51</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>227.83</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>228.15</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>228.48</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>228.8</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>229.12</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>229.45</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>229.77</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>230.09</td>
  <td class=xl159623 align=right x:num>25.49</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>230.42</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>230.74</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>231.06</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>231.38</td>
  <td class=xl159623 align=right x:num>2.23</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>231.7</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>232.02</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>232.34</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>232.66</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>232.98</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>233.29</td>
  <td class=xl159623 align=right x:num>12.16</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>233.6</td>
  <td class=xl159623 align=right x:num>14.9</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>233.92</td>
  <td class=xl159623 align=right x:num>3.5</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>234.24</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>234.56</td>
  <td class=xl159623 align=right x:num>2.11</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>234.88</td>
  <td class=xl159623 align=right x:num>34.12</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>235.21</td>
  <td class=xl159623 align=right x:num>34.51</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>235.53</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>235.85</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>236.17</td>
  <td class=xl159623 align=right x:num>188.94</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>236.5</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>236.83</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>237.16</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>237.5</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>237.83</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>238.16</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>238.48</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>238.81</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>239.13</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>239.46</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>239.78</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>240.11</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>240.43</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>240.76</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>241.08</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>241.41</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>241.73</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>242.06</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>242.38</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>242.71</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>243.04</td>
  <td class=xl159623 align=right x:num>3.11</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>243.36</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>243.69</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>244.01</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>244.34</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>244.67</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>245</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>245.32</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>245.65</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>245.98</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>246.31</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>246.63</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>246.96</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>247.29</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>247.62</td>
  <td class=xl159623 align=right x:num>2.21</td>
  <td class=xl159623 align=right x:num>35.69</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>247.96</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>248.29</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>248.61</td>
  <td class=xl159623 align=right x:num>264.52</td>
  <td class=xl159623 align=right x:num>1.7</td>
  <td class=xl159623 align=right x:num>41.96</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>248.92</td>
  <td class=xl159623 align=right x:num>296.01</td>
  <td class=xl159623 align=right x:num>8.19</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>249.19</td>
  <td class=xl159623 align=right x:num>321.2</td>
  <td class=xl159623 align=right x:num>8.96</td>
  <td class=xl159623 align=right x:num>43.92</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>249.47</td>
  <td class=xl159623 align=right x:num>352.69</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>249.74</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>250.01</td>
  <td class=xl159623 align=right x:num>421.97</td>
  <td class=xl159623 align=right x:num>11.26</td>
  <td class=xl159623 align=right x:num>42.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>250.28</td>
  <td class=xl159623 align=right x:num>447.16</td>
  <td class=xl159623 align=right x:num>11.78</td>
  <td class=xl159623 align=right x:num>40.39</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>250.55</td>
  <td class=xl159623 align=right x:num>453.46</td>
  <td class=xl159623 align=right x:num>11.52</td>
  <td class=xl159623 align=right x:num>39.22</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>250.83</td>
  <td class=xl159623 align=right x:num>38.43</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>251.1</td>
  <td class=xl159623 align=right x:num>459.76</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>251.37</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>251.65</td>
  <td class=xl159623 align=right x:num>3312.5</td>
  <td class=xl159623 align=right x:num>37.65</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>251.92</td>
  <td class=xl159623 align=right x:num>3343.75</td>
  <td class=xl159623 align=right x:num>11.01</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>252.2</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>252.47</td>
  <td class=xl159623 align=right x:num>9.47</td>
  <td class=xl159623 align=right x:num>0.88</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>252.75</td>
  <td class=xl159623 align=right x:num>6.91</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>253.03</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>253.32</td>
  <td class=xl159623 align=right x:num>302.31</td>
  <td class=xl159623 align=right x:num>1.43</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>253.63</td>
  <td class=xl159623 align=right x:num>226.73</td>
  <td class=xl159623 align=right x:num>1.56</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>253.95</td>
  <td class=xl159623 align=right x:num>1.88</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>254.28</td>
  <td class=xl159623 align=right x:num>1.91</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>254.6</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>254.92</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>255.23</td>
  <td class=xl159623 align=right x:num>3.16</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>255.54</td>
  <td class=xl159623 align=right x:num>3.65</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>255.86</td>
  <td class=xl159623 align=right x:num>4.12</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>256.17</td>
  <td class=xl159623 align=right x:num>4.55</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>256.48</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>256.78</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>257.09</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>257.4</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>257.71</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>258.02</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>258.33</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>258.65</td>
  <td class=xl159623 align=right x:num>4.16</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>258.98</td>
  <td class=xl159623 align=right x:num>4.08</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>259.31</td>
  <td class=xl159623 align=right x:num>2.93</td>
  <td class=xl159623 align=right x:num>14.51</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>259.63</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>259.96</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>260.29</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>260.61</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>260.93</td>
  <td class=xl159623 align=right x:num>17.65</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>261.24</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>261.56</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>261.88</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>262.2</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>262.52</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>262.84</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>263.16</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>263.47</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>263.79</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>264.11</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>264.43</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>264.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>265.06</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>265.37</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>265.68</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>265.99</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>266.29</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>266.6</td>
  <td class=xl159623 align=right x:num>11.76</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>266.91</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>267.22</td>
  <td class=xl159623 align=right x:num>2.29</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>267.53</td>
  <td class=xl159623 align=right x:num>3.14</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>267.84</td>
  <td class=xl159623 align=right x:num>2375</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>268.15</td>
  <td class=xl159623 align=right x:num>2343.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>268.46</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>268.76</td>
  <td class=xl159623 align=right x:num>10.98</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>269.07</td>
  <td class=xl159623 align=right x:num>2312.5</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>269.38</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>269.69</td>
  <td class=xl159623 align=right x:num>2281.25</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>269.99</td>
  <td class=xl159623 align=right x:num>3.09</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>270.3</td>
  <td class=xl159623 align=right x:num>2.85</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>270.61</td>
  <td class=xl159623 align=right x:num>2250</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>270.91</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>271.21</td>
  <td class=xl159623 align=right x:num>2.83</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>271.51</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>271.81</td>
  <td class=xl159623 align=right x:num>2218.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>272.11</td>
  <td class=xl159623 align=right x:num>2187.5</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>272.4</td>
  <td class=xl159623 align=right x:num>4.82</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>272.7</td>
  <td class=xl159623 align=right x:num>2156.25</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>272.99</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>273.29</td>
  <td class=xl159623 align=right x:num>2125</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>273.58</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>273.88</td>
  <td class=xl159623 align=right x:num>2093.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>274.17</td>
  <td class=xl159623 align=right x:num>2062.5</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>274.46</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>274.75</td>
  <td class=xl159623 align=right x:num>2031.25</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>275.04</td>
  <td class=xl159623 align=right x:num>2000</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>275.33</td>
  <td class=xl159623 align=right x:num>1656.25</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>275.62</td>
  <td class=xl159623 align=right x:num>1312.5</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>275.9</td>
  <td class=xl159623 align=right x:num>1000</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>276.19</td>
  <td class=xl159623 align=right x:num>1062.5</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>276.48</td>
  <td class=xl159623 align=right x:num>1343.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>276.77</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>277.07</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>277.37</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>277.68</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>277.98</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>278.28</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>278.58</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>278.88</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>279.18</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>279.48</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>279.77</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>280.06</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>280.35</td>
  <td class=xl159623 align=right x:num>1281.25</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>280.63</td>
  <td class=xl159623 align=right x:num>18.89</td>
  <td class=xl159623 align=right x:num>968.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>280.91</td>
  <td class=xl159623 align=right x:num>937.5</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>281.19</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>281.47</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>281.75</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>282.03</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>282.31</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>282.58</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>282.86</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>283.13</td>
 </tr>
  <td height=17 class=xl159623 align=right style='height:12.75pt' x:num>283.41</td>
 </tr>
 <![if supportMisalignedColumns]>
 <tr height=0 style='display:none'>
  <td width=64 style='width:48pt'></td>
 </tr>
 <![endif]>
</table>
</div>
<!--END OF OUTPUT FROM EXCEL PUBLISH AS WEB PAGE WIZARD-->
</body>
</html>
Are you serious? LOL
195*C = 383*F My engine would be toast by now if I had run at that temp daily driving for 2 years.
195 just seems so consistantly low. 2g's must run extra hot or something. In the summer time, its no fun to stand next to your front end. Mine is hotter than hell & im pretty sure others are hitting the 212 mark on daily. Ohio doesnt get hotter than 97.
Today was about 87* out.
