Coolant sensor confusion
srtkiller
129
Feb 6, 2007
Mesa, Arizona
I have searched for this but have not found anything for the 2g that was descriptive. I need to know which of the sensors on the thermostat case control the fans. My fans are not turning on and I have already checked to see if the motor is good and the connections are good. I need help ASAP thank you ahead of time.
On a 2G car, the ecu grounds the cooling fan relay to operate the cooling fan at the correct temperature (210 degrees I think), based on the input from the coolant temp sensor. There are only 2 sensors on the water outlet, 1 is the coolant temp sensor, & the other sensor is for the gauge on the dash. :talon:
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
