Coolant Sensor Issue?
jeremylee_7
161
Aug 25, 2003
Yuma, Arizona
Hi, i just replaced my thermostat on my 1g the other day, and when doing so the brittle wiring broke off of the coolant switch plug on the top of the housing (the sensor plug that has white female end, and black male end).
For the weekend while the wires were broken off it threw a CEL, which was obvious since there was no reading from the sensor.
Well i get a new plug from junk yard today and wire it up. My car is still throwing a coolant sensor CEL (code 0021) and when i run dsmlink it says my coolant temp is 306 DEGREES! But get this the dash gauge has stayed just under half way since i changed the termostat.
Could the senor itself be bad, or is it some other problem?
If anyone can check their 1g i have the black wire on the top and the green/yellow wire on the bottom of the plug, I am pretty certian it is wired in correctly but the wires broke off right at the connector so I am not 100%
Are you talking about the radiator cooling fan switch in the top portion of the housing, or the temperature sensor (not for the dash gauge) in the lower portion of the housing? (Does the cooling fan cycle when you leave the engine idling?)
Cooling fan does come on, the switch that had the broken wires was the top one, the switch not the sensor
Was thinking that maybee the switch wire is damaged somewhere, thus adding alot of resistance to the wire and giving a much higher reading then it should.
The switch isn't used for taking readings, that's the sensor. The switch is used to control the fan.
which one you talking about... red, or green?
even though you broke the "green" connection, it only controls your fans. your coolent temp sensor "red" is probably bad. the way you explain your computer telling you the coolent is 306 degrees points towards this sensor (since your gauge is controlled by a completely different sensor.
hope this helps
-Devs
The green is the one i broke, the switch, which i got a replacement and wired.
Although since my coolant temp reading is off the chart (306 degrees) i was thinking the red, the sensor, could be having a bad wire issue as well, thus having extra resistance, and thus giving off an incorrect temp reading.
Sorry about the confusion guys, guess my mind is a little too fried from trying to diagnos this screwed up ASP code from this webpage I am taking a look at.
My wiring and jacketing around the thermostat housing was old and brittle and I ended up having to rewire some terminations and rewrap the harness bundle and pigtails. I had a new temp sensor in there, but before I rewired it, the engine wouldn't even fire.
  • For sale 2g 2G Clear Tail Light Set
    2G Clear Tail Light Set $550 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
