ground issue maybe?//coolant sensor?
infantry
48
Jul 30, 2008
cedar falls, Iowa
is it possible to have power to turn the engine over but not enough to get spark?
i relocated the battery to the trunk and now the car will just crank,but not fire.i can smell fuel after cranking and used a spark tester and didn't see anything.only other thing i did was remove some of the vacuum lines.
my thought was maybe it's not grounded good enough.
any suggestions?
ok,so after doing some more searching and reading i came across something about a coolant temp sensor..so i searched for that and did some more reading..
i had a broken wire there and the coolant was low.now i can get it to start but it sounds like it's running on 2 cylinders....now i'm at a loss for this issue
Check and see if you accidentally unplugged, tore, whatever any of your wire harness' because working especially ON your battery and cables could cause any of the Bakelite to break, or spliced-in wires to come out and go easily un-noticed. I had it happen before, and its usually due to being corroded with age.
i keep going over the wires to see if i missed something or forgot to plug something in,and haven't found anything
Just throwing this out there, but its possible you may have shorted something on your transition from your engine bay to trunk... highly unlikely since you didn't say you saw any arc of any sorts.
-Is your CEL on?
-Does the wire that you said was broken look like it broke because of age or abuse?
-Have you checked your cylinders to see which (if at all) are not firing?
  • For sale 2g 2G Clear Tail Light Set
    2G Clear Tail Light Set $550 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
