coolant/radiator confusion?
j5productions
76
Nov 15, 2012
Newark, Delaware
Alright guys I'm confused here. So my car runs and doesn't over heat, but When I turn off my car it leaks from the radiator /lower hose. I have a replaced the hose and now I just ordered a new radiator. My confusion is, even though I have had 3 huge puddles of coolant loss, It's still topped off? I know that it has a tiny crack so this is why I'm replacing, plus my coolant seems like it has tiny little black things in it i assume from a stock Radiator. I just want to know why It's still topped off after losing so much. It isn't coming from that extra coolant thing (forgot the name :Lol:
It's probably coming from your coolant reservoir. It's supposed to top it off like that. Continue with the radiator replacement and see if the leaking stops. Beyond that you should do a complete coolant flush. Any shop can do a pressurized leak test which will make leaks more obvious.
