Coolant reservior tank question
Mounting? No, it's good to have it in place but I have mine sitting where my cruise control box was next to the battery.
I had to relocate mine to make room for intercooler piping. I made a custom zip tie bracket :) As for the hoses, the one on the top is attached to the thermostat housing for the coolant to overflow into when the cap allows it and the other end hangs free in case it has too much coolant. It runs out of the tank.
I installed my short route FMIC and found out that the stupid coolant bottle can be difficult. What I ended up doing was mounted in the area that the stock side mount was. I actually have a huge transmission cooler and my coolant overflow in there and it's nice. I made the hole big enough that if I pop the air filter off I can pull the top off the coolant overflow and check the level.
