Coolant overflow grommet gasket
mschlanglv
147
3
Feb 16, 2008
Duluth, Minnesota
I searched quite a while for a replacement grommet for the low coolant sensor and finally found something that works.
Item Details
It's from a mid 80's GM, my local Checkers had it in stock. Any store that carries the Help! Line of parts should be able to get it.
To install it, I first slid it half ways on the sensor, then I used a screwdriver to carefully push the seal lip into the overflow bottle. I also used some silicone spray to help things along.
Hope this helps someone else with the same issue!
