Coolant feed line for turbo
goldeninja20
589
3
Dec 5, 2010
Norton, Massachusetts
I am grabbing all of my fittings i am going to need for my set up. I am running stainless steel oil feed and drain along with coolant lines. The only problem is that i cannot put a fitting in the thrmostat housing because there is no thread. I don't really mind taping it, but im afraid it may leak. Since i do not have AC could i use the tap for the Water tempature switch for AC. Also what is the thread of the AC switch (If you guys think i should use it instead of drilling out the factory spot).
There is no A/C switch in the 2G thermostat housing.
There are two sizes of threads used for sensors on the thermostat housings: 1/8 and 3/8 BSPT. You won't easily find a fitting for those so you'll likely end up having to tap something somewhere anyway for the stainless fittings.
Glad you told us. Fill out your vehicle profile information.
Yes, you can use the A/C switch location on a 1G housing.
Because the 2G feeds the turbo coolant from the block rather than the thermostat housing.
The 1G thermostat housing will bolt up to a 2G head. A 2G thermostat housing will not bolt up to a 1G head, however.
