JamesG
- 0
- Oct 24, 2011
Spring Creek,
Nevada
After replacing all of the heater and coolant hoses on my 1990 eagle talon tsi awd.. I filled it up with antifeeze after making sure all hoses were properly fastened. After I finished installing them I attempted to start the car and all it would do was crank the engine, it wouldnt turn over. I checked all wire connections to make sure I didnt disturb them. I couldnt find any issue, but it still wont start.. I would like to fix it myself because I know it is something I am just simply over looking. Please if anyone can help with any information it would be greatly appreciated
also the car had no issues starting or running before I replaced the hoses. I only replaced them because they were worn and a few seemed to be lightly leaking..
.... Please close this post out as "Solved" so that others may run across it and hopefully solve a problem such as you had, it happens so don't be embarassed. But, you learned some troubleshooting along the way so consider that "valuable knowledge". Now, you will be able to solve any problem that comes your way and if you don't you always know where you can find some help. Good old flammable liquid comes in handy when you least expect it but, does a very good job at troubleshooting. Handy to have around at all times. And they say you can't fix a car a 1,000 miles away...
