converting my internal to an external wastegate. help!!
sonicx13
Dec 1, 2008
revere, Massachusetts
hi im getting alot of boost creep and i was told that if i convert my wastegate to an external one, that would solve my problem. I have a 16g turbo with the stock manifold and megan o2housing with the external dumb(if that makes sense).what do i need to change/buy in order to do this? the cheapest and easiest way possible .. thank you
http://www.dsmtuners.com/forums/new...internal-external-help-hook-up-wastegate.html
http://www.dsmtuners.com/forums/newbie-forum/259152-converting-internal-gate-turbo-external.html
http://www.dsmtuners.com/forums/new...l-wastegate-external-wastegate-what-need.html
All you have to do is buy an o2 housing that supports an external wastegate and an extermal wastegate and remove the internal one. Or you can weld the flapper shut and run one off the manifold if you get a new manifold. Either way is fine. Going to be around the same price if you are looking for cheap.
If youre running an o2 dump you shouldnt have creep problems because thats kind of turning it into an external like setup.
But if you want full external setup, i can hook you up with the manifold with the 38mm flange for about 160 and the wastegate. Then you will just have to weld the flapper shut on the turbo and youll be golden.
