Alextrash
- 1
- May 15, 2005
Mission,
Kansas
My 1998 Eclipse Spyder GS has developed a problem with the convertible top. After starting my car or turning the key to the On position, I can hear an odd noise coming from behind me, near the rear speaker. Presumably this is the convertible top motor. The sound is a short "squawk" noise that only lasts a second, it repeats every 15-20 seconds. This is not a clicking sound or the normal gears spinning sound, but more like the motor is jammed or stressed. The other motor on the passenger side is silent.
This has happened intermittently a few times over the past year, and each time I noticed that the top would not go up or down. Now it is happening consistently. My top is currently closed. Pressing the top up/down switch on the dash has no effect. The windows do not go down. The last time I drove this car, about a week ago, there was no odd noise and pressing the up/down switch worked as expected. Several years ago I replaced the bent arms with the better Ebay ones, and have had no trouble with the arms and mechanical operation since.
I've read many posts regarding the manual switch in the trunk, the shear pin repair, etc. But no posts describe the sound I'm hearing or the fact that the windows do not go down while pushing the switch.
Any troubleshooting help is appreciated.
