2G Compression Test
Check fuses first does your check engine light come on when you try to start it then I would go with ignition module
Well it looks good, but I wonder why you'd suspect compression if you know there's no spark.
I think "How to Diagnose No-start" and other threads cover the usual suspects in the ignition system: ignition coil, wires, ptu, ecu, I think also mfi relay. I think the FSM has some charts on diagnosing/ tracking down a no-start ignition issue. If you have a new crank sensor it's probably not the problem.
are u sure all of your grounds are good..... i spent two weeks trying to track down a no spark scenario and it ended up being a bad ground
