compression test?
93AWDDSM
883
40
Jan 1, 2009
Vancouver, Washington
I have a 93 eagle talon tsi and i am going to be doing a compression test soon, what psi am i looking for per cylinder?
I would be concerned with anything less than 135, also anything over 145 is good, 150 is normal. They should all be between 10-15 of each other as well.
this.
and actually its 15%, the lowest cylinder must be no more than 15% less than the highest cylinder to be in-spec, according to alldata. so if your highest is 170 your lowest cant be any lower than 144.
1g motors have low compression from the get go. So from what I've seen on a 1g motor, 150 in each cylinder is a pretty healthy.
