1G Compression test
salvador2330
45
May 11, 2010
northlake, Illinois
Engine has about 50-60 miles on it and I did a compression test and they were 156-160 on all four cylinders Is it normal or the rings are bad.
Yeah
Those are good numbers. Remember to do lots of engine breaking, allow the car to build boost, but don't put your foot in it constantly. ^^ Change your oil after 100 miles, 200, 500, 1000, 2000, and then every 3000 miles.
Yeah
You could likely see those numbers go up a little bit over the next few weeks if you drive the car correctly. ;3
Good luck!
