Compression Test Results... OK?
dashtz69
138
Apr 16, 2003
First I would like to thank Xceler8n for trying to help me through this. I finally got it all figured out. Well here are my results...
From left to right
1- 190-190
2-185-190
3-180-185
4-155-160
I did each cylinder twice. The fourth one is little low, very close to that 15% serviceable limit... That plug looked the worst too when I pulled it out. Had black all over it. However, my Chiltons manual says that if your plugs are too cold (BPR7ES) it can foul quickly. So I am going to put 6es in there and see if that will help. I still can't believe those numbers are that high though. I didn't think they were that high stock. This was done with the car full warmed. Something seems wrong though... 1995 Talon TSi with 123K miles...
Your first three numbers are good. The fourth one is bad. Check them again in a day or two, and if you get similar results do a leakdown test on the fourth one. It might be a bad ring.
-T
hey no problem man, the 4th one may be bad becuase of youre battery!
my last number was lower than the rest, went back out went for a spin, and then bam right where it should be, give it a shot.
since 7 shots at a test would drain youre battery
Thats what I was hoping. Plus the car was cooling down a little too. I don't know though, because that plug looked like crap. We'll see... I'll check it tomorrow or Friday. Thanks
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
