Compression Test Results
gstbuford
98
Jan 10, 2008
Prairievlle, Louisiana
Well I purchased a JDM 6 bolt from osakajdmmotors.com. First thing I did was drain the oil and drop the pan to have a looked at everything. To my surprise, the oil looked milky WTF After seeing that I decided to do a compression test. 50 across the board. Any thoughts? I am thinking popped head gasket but I know it could be other things. Im pretty disappointed considering I payed 1500 bucks for the motor and their return policy consist of a 50% re-stocking fee. O well you live you learn I guess. Any thoughts? Thanks guys.
-Stephen
have you called and asked them what they will do for you since it sounds like they shipped you a bad engine?
do you have any idea how long the engine has been out?
dose the engine spinn over proper?
well today i changed out the head gasket and re timed it and the compression is reading as follows
1st cylinder- 145
2nd cylinder- 130
3rd cylinder- 130
4th cylinder- 90
The battery we were using was gone by the time we got to the 4th cylinder. It was dark and just decided to let it charge over night and try again tomorrow. The funny thing is that the headgasket wasnt the problem. The old one was in good condition. :confused:
The Compression is going to be low if the engine is cold. You are supposed to do a comp test when the engine is at operating temp and with the Throttle blocked OPEN. Did you remember to open the throttle?
i put some oil in the cylinder that held 90 psi and it jumped to 150. and yes i made sure the throttle was open. any ideas?
Dude if I did a comp test on my brand new engine while it was cold I would probably get around 90.
Your pistons and Rings expand slightly when they are hot. This will give them a tighter fit and obviously higher compression. If all of you cylinders are the same or pretty close, then you'll be fine trust me man.
I had 90 psi compression while the engine was WARM last summer in my old 7 bolt and I still ran a 13.8 like that.
This is exactly what gstbuford looked like when he was reading the compression guage
hopefully its just light tarish/rust not letting the rings/valves seat....MAYBE a little run time will get it all to seat back in.
Is this a "brand new" rebuild or a used engine?
with a little luck it is just a small piece of trash between the valve and seat, a gasket flake or piece of carbon.
thats an understatement LOL
o jon that flywheel will be here tommorow :cool:
