compression test results
Consistency is key when doing a compression test, its when you see one or more cylinders that are low is when you need to worry.
Did a compression test about a month ago.
150 across the board.
this is a 6bolt stock w/ about 15k miles of mostly weekend wars.
does it sound about right?
or should i start saving up?
Did you do the compression test correctly? If you got 150 when its cold, that means nothing.
James :laser::talon:
