Compression/Leakdown test results
bcjjones
509
6
Nov 3, 2011
Austin, Texas
Compression Test results:
Cylinder 1-4
148psi, 150 psi, 150 psi and 152 psi
Leakdown check results:
All around 10-12%
Leakdown tester was the cheap harbor frieght low psi tester. Doesnt really work very well and I dont think the rings can seal correctly under such low(around 10) psi right? Because on all the cylinders the air was leaking past the rings into the crankcase, could hear it threw the dipstick.
Couldnt find a good comparison results for the same car i have (1992 Eagle Talon TSI) need to update my profile sorry. That seem pretty normal for results?
if you can hear it through the dipstick than that is your rings. 100 shot of pressure should tell you. harbor freight is cheap stuff but should be close to telling you whats wrong and whats not. one way to check it rings went bad is to check if your burning oil. what the site mod. post is also a good thread to learn too. with good compression i wouldnt worry that much about the leak down test.
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
