Complete suspension setup, input?
1990AWD
Supporting VIP
8,541
26
Apr 27, 2009
Langham, SK, Canada
So, I need to completely overhaul my suspension so I need to start saving and piling up the list of parts I want. If you think I've missed something or there is something that could perform better than what I have on the list, let me know.
My car is going to be used mainly for street/strip but I want it to also hang tight in the corners. Currently the car weighs about 2950lbs without me in it, but I would like to take another 1-200lbs out of it.
Energy Suspension front subframe and control arm bushings, rear lower control arm bushings
RM front and rear sway bars
Megan Racing front and rear strut bars
Jay Racing rear toe delete
Bulfab rear subframe bushings and tubular mustache brace
new upper rear control arm (the tubular DIY ones)
new wheel bearings and ball joints
Paul Volk's tubular rad support, north/south bars, and subframe braces
Koni/GC coilover setup
front camber plates (what brand is good?)
What do you guys think? :hmm:
Pretty sure with tubular rear control arms you can't use the rear sway bar because it no longer has a provision for mounting the sway bar links.
True, forgot about that. Maybe I'll just do the upper control arms then.
