Cometic Headgasket Size
DStarMotor99
Apr 4, 2006
Miami, Florida
hey guys i tried searching for the cometic headgasket size and I didnt find any thread about it . I went to Concept Illusion website to buy the headgaskets and they are asking me what size of headgasket and I dont know which one to get .
87.5mm or the 88.5mm?
.....neither
OEM MLS, get it from Bruce @ the Parts Dinosaur Store :thumb:
DStarMotor99 said:
is that one good for when you go turbo?
Yes.
Stick with the MLS from Parts Dinosaur. Not only will it be all you need, but it will actually show up promptly and be the right part when it does. ;)
You asked us if it would hold up to the power when adding a turbo, we said yes. We didn't give any limitations etc, now you ask how much hp the headgasket will handle. The one we're reffering you to is an OEM replacement, and you won't need to worry about having to many horsey powers ;)
so what if I want to stay with the stock headgaskets? would it be fine? im planning to go around 270hp
Are you not paying attention :confused:
That headgasket we're referring to you is an OEM replacement, yet it's the Multi Layer Steel and will withstand what you're gonna throw at it.
yea i know that one holds but im talkin about the one i have now in the engine ?
Okay I see, X I think you misunderstood what he meant that last time. I would like to say the stock headgasket may be good up to around the 10psi mark. Then again, it could go out around the 5 psi mark. All depends on it's current conditon.. With the ones X was showing you, there wouldn't be any reason to worry about what it can handle. They're made for that kind of abuse, or HP per se..
thanks Blitzeclips
