1G Cold start on 4g37?
Sullbren17
173
Nov 29, 2012
Chadron, Nebraska
I know I'm not a noob on DSM, but I am a noob on the 4g37.
Ever since I've got this car that first start is a real pain. It seems that I have to crank the motor, then cycle the ignition. And crank again. It with try to fire but seems like its only sparking one cylinder. The colder temps from outside make it harder to get it started.
Today it was about 37 outside, and I hooked my car up to jumpers, seemed like it took me about 45 mins to get it started. In warmer temps like 80 it takes about 3 tries to get it started. When I do get it going it will idle at 500 -700, and if I don't hold the gas it will die. When the motor gets warmed up it seems to be fine, except it idles at about 1100 revolutions.
I did some research on it and every person who has a similar problem doesn't give feed back! And my thoughts when I try to figure out the problem in my head is that its not getting a good spark for some reason. My battery needs to be replaced but that should not be the cause to the issue.
I read somewhere about the barometric pressure sensor could be bad. I thought to myself WTH is a barometric sensor why would a car need to know when its gonna rain or snow LOL. But I was told its to help the ECU with your a/f ratio. But still doesn't help I tried checking the CEL but I'm not getting anything from the light.
If anyone has any ideas that would be awesome!
Look into the Coolant temperature sensor. It's a two prong plug on your thermostat housing that tells the ECU what temperature the car is.
