InfiniteGSX
- 3,182
- 16
- Dec 10, 2002
Tijeras,
New Mexico
Alright. Got this 97 GSX for a direct trade for my blown up 94 Talon. Sexy lil black bi***. But it was halfway parted out and hasn't ran in almost 5 years! Not because of damage, because the people were stupid. It had bent shift linkage and they thought it was a trashed transmission. Easy fix.
So I start out by restoring it. Get a manifold, Stock Turbo, Sell the large injectors it had, Ordered a FMIC Kit, got a radiator, repaired some damaged wires. Got it to start. But when I first started it I had no MAF. I mainly just ran it to confirm certain things worked like the water pump and that there was no knocking rods or anything. 6bolt motor has 120psi across the board. Not inspiring but not bad. I've had high 11 second DSM's with the same compression. However not my issue. I got a MAF Sensor finally and it started getting cold, like cold weather. I couldn't get it to start at all. So one day, a couple days ago it was really warm outside. Took about an hour of "tricky" cranking to get it to run. I would have to just tap the starter to get some fuel in, tons of times. You'd hear it pop, and then pop pop.... But wouldn't start. Finally it started, then died. Started and ran for a minute or less than died. Finally it eventually stayed running. I let it run to confirm it was running on 1 cylinder. Then you could hear it start to "catch up" and another cylinder would fire, then another... It was finally running somewhat decent. Turns out I had a completely dead injector. So I replaced it right away. It started right up and I adjusted the new Biss Screw I got for it since it had non when I got the car. Not sure I'm on target since the entire gauge cluster is dead, but I dropped it to a quiet idle. I have video, (ignore the exhaust leak sound, I need a welder to weld my 3" downpipe together)
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/LOOkR4XOZ4c?fs=1&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/LOOkR4XOZ4c?fs=1&hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
I drove it around the block, actually a couple times and it ran GREAT! Goes through the RPM's very smooth like. But this was all in a warm day. Today and tomorrow is very cold! I tried today but only for a few minutes and it fired twice but no start.
I don't have a autozone close enough to test the codes. I think its only a O2 Code. But O2 Sensor wont prevent the car from starting, It should start but just not be up to par. So what else should I be looking at? Sticky Injectors? IF so what would I do about this if I can't replace them cheap... What about something in the TB? I remember last year when I had a blockoff where the FIAV/ISC was it would take a lot of convincing to get the car to start. I ended up replacing it with a new Unit and said screw the blockoff plate.
What about this ECT? I'm using a 1g Water Neck since I couldn't find a 2g Water Pipe. I know the 2g has two sensors and the 1g has like 3. There is three wires dangling that I know goes to the 2g water pipe. Two have pin sockets on them but no plug. I'll fix this soon but I assume they plug into the matching top 2 wire plug. And the single wire goes to that little single wire sensor...
But what I was reading on here is that the ECT on 2g's is 1 wire and on 1g's are 2 wire with the plug in a T Format....
anyway what do you guys suggest?
Car:
1997 Eclipse GSX
6Bolt Motor (120/121/124/120)
7bolt Head
14b Turbo
2g Manifold
3" Real Turbo Back (3" Tubular O2 Housing)
SSAC Short Route FMIC
Stock 1g Injectors
Stock 2g MAF
98 Black Plastic ECU
BPR6ES (NEW)
Coil On Plug
"Car that hasn't been daily driven in over 5 years and possibly only driven at all in 4 years, by me in the past couple days"
Car:
1997 Eclipse GSX
7bolt Head
14b Turbo
2g Manifold
Stock 1g Injectors
Stock 2g MAF
BPR6ES (NEW)
Coil On Plug
