Coil pack removal without removing fuel rail?
Hardcore1
50
Aug 16, 2013
Arvada, Colorado
I am probably sure this has been asked a thousand times but I am going to ask it again.
I am putting a spark tech system into my 4g63 and I really don't want to remove my fuel rail is there any way to pull the coil packs without doing it?
I couldnt see why not. It will just require more finessing to take out the coil pack with rail on compare to taking out the rail first. Just remember to disconnect all the wires that connects to the coil pack then pull out. My coil pack had 4 or 3 bolts that i had to take off first on my 6bolt motor swap. Not really sure about the 7bolts.
I did it before when my coil packs went bad, replaced it with another oem coilpack. it can be done just unplug the spark plug wires obviously and just move everything out of the way. I took it out by unbolting it and pulling it out thru the side on the right. Just requires alot of patience and finesse. Trust meROFL
