1G coil on plug setup ignition setup...
Status
Not open for further replies.
IceDragon
547
Jul 13, 2004
Gilbertsville, Pennsylvania
I have a 93 Laser with a N/T 2.0 under it and I want to use a coil on plug setup, but I also want to be able to amp up the power going to the plugs for more spark, does anyone know how I can do that easily?
why? do you have one that you got for cheap? i don't see how much benefit you'll get from a COP setup on a car with minor bolt ons. if you're thinking of buying one, don't. you could spend that money on more beneficial parts.
however, to answer your quesion. the best thing to do is upgrade your plugs and wires. other than that, the stock ignition system is pretty good as it is. just make sure your ignition coil and ic module are functioning properly.
here are some threads you might find useful:
http://www.dsmtuners.com/forums/showthread.php?t=97714
http://www.dsmtuners.com/forums/showthread.php?t=131745
http://www.dsmtuners.com/forums/showthread.php?t=145853
http://www.dsmtuners.com/forums/showthread.php?t=151831
Status
