cobra calipers clearance
GST_IceTea
105
Apr 7, 2011
West Boylston, Massachusetts
hey guys, im looking to see if anyone would know if the RTM cobra caliper brake kit would fit on my 2g. i currently have kosei k1 17x7.5 et45 w/ 235/45/17.
We have a VERY short list of rims that are known to work and those rims aren't on it. Fact is, we don't get a lot of feedback from guys that have bought our brakes. We suspect a lot of guys use spacers to space whatever rims they're using to get the brakes to clear. By the way, there's a bit more clearance on the Cobras over the VR4s.
im performing a similar set up and all the input I've received and dug up has mentioned a minimum of 17 in wheels with a 45 offset and depending on the type of rims you may need to run a 3mm spacer. this info is for the 3000gt four piston calipers so maybe slightly different on the cobras. hope that helped
