Stainbox12
- 378
- 7
- Jan 3, 2006
Panama,
Central America
some weeks ago my engine was rebuilt, though after that, i felt like the rpm´s would raise fast as usual but the car wasn´t displacing, i tracked down the problem to a slipping clutch issue, i spoke with the mechanic who told me that it was slipping because the lengh of the actual rod on the slave cylinder (very large), i took it out about 3 days ago, without bleeding the entire system, and i cutted it to spec (3.5¨ aprox). Now the car won´t engage, kinda like the slave isn´t moving the rod completly, i have rebuild the slave and the master with no luck. i checked the clutch fork, and its in the middle towards the drivers side (which apparently is normal) i have bled the system countless times, and nothing changes, the clutch pedal is still very soft, like it had no pressure. i also tried ajusting the master cylinder rod, and it made the clutch come up higher, but the pedal still felt soft. whenever i have my friend press the clutch, i see that the fork would move only about half an inch, and obviously that´s not enough to make it engage into gears. i have tried multiple lengh rods, made by myself, but i don´t think thats the real fix for the problem. i even checked that the bore of the slave cylinder was correct whic for an eclipse GSX is 3/4 as far as i know (unless i got a wrong slave). i dont think my fork is bad nor i have to shim it, because 3 days ago, as i said, when i cutted the large rod (the one that came with the car) to stock spec, the clutch enganged, but very very low, and again with not much pressure. any input is greatly appreciated, i need help on this one guys.
. i checked what you said, about the pedal. its completly leveled with the brake pedal, when i took it out it had the half inch play i said, but i unscrewed everything and screwed everything back in place, and the shaft play disappeared. i reassambled the pedal assambly without welding it, because it was fine for now. if it develops the mentioned problem later on, ill take it out again, i got no problems with it. Now, the clutch pedal is harder, but not enough still to move the clutch fork for engagement. im truly stuck. i will try bleeding one more time, and if that doesn´t help, i guess the transmission would need to come out. thanks for your help oldman, you are really helpful
Good luck.
