arabeclipse
- 119
- 0
- Sep 23, 2011
detroit,
Michigan
Believe me guys, I've been searching for two months on this. I have even followed jack's transmission video, read that famous clutch adjustment website, watched Jafromobile's video, and read basically every thread on here about clutch adjustment. I've tinkered with it and I can't get it right.
My clutch is dragging (OEM clutch but newer master cylinder) and even at a dead stop my car won't go into first completely sometimes. I have to put it in fourth then first. Reverse feels chunky no matter what. Once in a long while grinding in third.
I busted the nut (shut up) loose and turned the rod counterclockwise a half turn. And that's when I started getting the stuff I just mentioned above. So I raised the pedal height by half turn of the cruise switch and its still the same. Also bled the line and there's no air what's so ever. Keep turning the rod different ways only half turn at a time and its not getting any better. My engagement continues to be so close to the floor, about 1.5".
Basically I can get it to be a little better but I can't get it buttery smooth and stock notchy shifting. ever since I bought the car, downshifting into second SOUNDS like a grinding and rubbing sound but I don't feel any grinding. I can't make this go away.
Am I missing something here? This is my DD and to deal with this is really annoying and obviously doing tons of harm to the drivetrain. I need this car to last.
