1G Clutch switch/2 step
a91eagletalon
Supporting Member
278
13
Aug 24, 2005
Norfolk, Nebraska
Ok so I have v3 dsmlink and I believe my clutch switch is giving me problems or something at least is
I believe the car never did this before but I now just noticed it
Ok
So I can start the car with out pushing in the clutch but that I believe that has to do with the starter switch on the clutch pedal
So when I rev the the car up sitting still and the clutch out the car will rev to what the 2 step is set to not to the rev limit
witch is no big deal but I was thinking about using the no lift shift setting and it won't work right because the car thinks the clutch is alwes in
I tested the lower black switch on the clutch peddle and it still works and is plugged in
Is that the one dsmlink uses to control the 2 step and no lift shift
So if the switch is still working what is giving me the continuous clutch signal
Thanks guys for you help
Car drives fine
It is set to turn off at 8 mph in witch it dose I can rev to full rpm when I am moving over 8mph
But my no life shift will not work because it will engage the no life shift as soon as it gets to the set rpm not after I push in the clutch
You do have the clutch cut wire installed? Dont just test the switch either. Make sure it's being physically pushed. Worn pedal assembly clutch pedal wont come up all the way and wont push that switch. Pedal assembly can also be missing the little rubber plug if I recall. Go look.
It most definitely is being pushed in all the way
Clutch cut wire ? Not sure
The car came with this stuff done to it I can't say for 100℅ sure it hasn't alwes done this sense I bought it because I don't rev it up that high for the hell of it all the time so I haven't noticed it till now
I will have to look in to installing the clutch cut wire because it dose not have one plus it is on a 90 car so I can't just buy the cut clutch wire and install it but still should not be a prob
As far as the 2 step the cut clutch wire fix that problem at all or will it just stay the same as it is
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
