Clutch sticking to floor, 97 GSX
Junzu
145
19
Aug 21, 2021
California
Newbie here, my clutch is sticking and clutch fluid was bone dry when I picked it up. Put in some brake fluid into the clutch master cylinder and pumped it but clutch still has no pressure, checked for leaks with clutch pressed in and saw nothing. Master cylinder looks like it's pretty new... could this be a problem with the clutch rather than master & slave cylinders? Thanks!
Try to manually (with your hand) push the clutch fork end towards the slave cylinder. Wiggle the fork itself, is it free and feeling intact? Then try pushing the slave cylinder rod back towards the cylinder itself. Does it push back with a bit of resistance?
