clutch safety switch and my cruise control still works
I have a 90 laser, and was under the impression that the cruise wouldn't work after removing the clutch safety, but it still does. hmmm:thumb:
It sounds like you're happy with it not cutting out & just shift quick hey.
You can use the 2 clutch contacts with a momentary button if you like.
Meaning you setup a button anywhere you like & can hit it to coast at will
without needing to hit the brake !
I set this up on all aftermarket cruise controls. Set, resume, coast.
I have set up one car with 2 brains, 2 switch boxes, 1 vac controll.
With this you can set 2 speeds, you have 2 resumes & 1 common coast.
Cheers !
