clutch replacement
scaryfastdsm
70
Jan 9, 2008
bonney lake, Washington
hello its this a good clutch for my 350whp awd 91 gsx.......
Manufacturer: Spec
Product: Stage 3 Kit
MSRP: $359.00
(MSRP is typically higher than most shop prices)
Description:
This is for the weekend track patron. With a torque capacity of 415lbs this monster will carry your sub12 second monster down the track with ease while maintaining a reasonably stock feeling peddle pressure. The stage 3 Features a High-clamp pressure plate and 3-piece disc with carbon or ceramic material.
im goin to have it replaced soon so i need some info.....i only have 400 to spend on a clutch and my car is a dd....
if you can spend another $25 you can get a reliable act 2600 from maperformance.com, the act clutch is tried and true. Otherwise do some searching about spec. I believe a couple of people are running them on here.
i would just buy the spec, ther a reliable company if it says it will handle 415 tq well go for it test it out see what happens. thats not sarcastic by the way, im serious.
i have had my spec for 2 years now. its seen alot of hard launches over thoes 2 years on a 20g. as soon as i threw on my holset i could no longer launch my car because of the power i am currently putting down. if your set on a spec clutch get it thought titan motorsports. its like 275 bucks...
