Clutch replaced and now no power
DearDoger
123
Jan 26, 2008
Battle Ground, Washington
HELLPPPPPPPPP I replaced my clutch got everything put back together. I went to start it up and I got no power at all not to the dash or anything I checked the battery, all the fuses, the grounds. I dont know what else it could be please any ideas or suggestions would help.
As Mr Peepers said, clean the posts and terminals with a wire brush and make sure they are tight. The only other thing I can think of is the battery drained while you had it out, check to see that it has a full charge.
The battery has a full charge the one thing i noticed was the ground cables were somewhat fraid but not too bad I cant figure why im not even gettin power to the dash
If you followed a guide, look back through it and check over everything you touched. I can't think of anything besides the battery, fuse box and grounds. Starter perhaps, but that wouldn't affect the dash lights.
I removed all the componets of the air conditioner in the engine bay while i was in there could it have anything to do with that
You may need to replaced the ground wire you were speaking of. Check your grounds again and all related connections you removed during the clutch install.
Thanks for all your ideas please keep them coming i need this dsm to get me to work. What could be the worst possible reason for this problem.
