Clutch problems
k3k0a
Jan 12, 2003
ive searched all over these boards and ive found a lot of people having trouble with act 2600 clutches..... ive tried the extended slave rod, the pedal assembly is fine, new master/slave cylinders....ect. but i wanted to know could i just put a 2100 or any other clutch that no one else has problems with back in and will it work fine?
i would just try and put the 2100 back in but it might not work, i remember when i put the 2100 in at first i had the common problem. then i put the stock clutch in thiniking it would be fixed but it didnt. btw didnt you have a laser that had the eclipse body kit on it? whatever happened to that
