Clutch problems, replaced slave and master
awd4g63tBOOST
Jan 18, 2007
Buffalo Grove, Illinois
I recently replaced my clutch master and slave cylinders. I did it because my old master went out on me. Now the clutch drops to the floor when pushed in (doesn't depend on pressure) and the car will not go into/out of gear. I believe the master and slave I received and installed was for the n/a cars, not the turbo cars. However, I am not sure because I do not have the invoice for the parts with me. Does anyone know if these will:
A) Bolt up?
B) screw up the shifting process like I am experiencing?
Thanks a lot guys, any help will be appreciated.
-Tony
same happened to me when i replaced both and also the clutch. would gear in or out. i was about to crack openthe tranny again after two days of trying. turned out to bethe adjustment screw where the pedal meets the firewall under the steering wheel.
if not clear enough p.m me i went through the whole process and now my clutch good. So i should be able to help. K.I.T
